failed attempt to load pic,abort
hopefully the first of many pics,it`s not done but l couldn`t wait any longer
my life begins at 150MPH Last edited by raceman; 06-01-2004 at 06:42 PM.. |
l`ll keep trying to load pics..
my life begins at 150MPH |
this was a test pic.Car is an 84 that l`ve owned for eight years.lt`s under construction right now but nearing completion..
my life begins at 150MPH Last edited by raceman; 06-01-2004 at 07:10 PM.. |
silver bullet carbon fiber door handles
l`m into the carbon fiber,these are shells l applied over the heavily modded stockers
silver bullet front end pics
l`m still testing the pic hosting feature,sorry about the resolution
"C-Rations"
Nice ride! Is that a Cabriolet?
John The Stable: 1985 Carrera Cabriolet (RoW) Sold 2002 Chevy Tahoe LT (The Wife's) 1999 Chevy Silverado (Parts Hauler) 1969 Volkswagen Beetle (Purchased From Original Owner) I'm slower than the guy in front of me, but faster than the guy in back of me. |
Kinda zoomy lookin; I wonder what it would take to make real ones...
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
custom door speaker enclosure on silver bullet
there was a company making these and advertising in Excellence for a short time.l bought the first pair sold off the line with MB Quart speakers already installed.
Thanks amigo,it`s a sunroof coupe but from the angle l took the pic from it`s hard to tell.Do you notice anything about the fenders? the car is an 84...
Ahhhhh 933 lights
Thanks Todd I drank what? = Party out of bounds - PriceLESS - BudWIZER "Boy Im gonna burn you a new one! - A new what officer?" = night in jail 993'ish Widebody bastardo http://hypertec.ws/todd_porsche/photos/
pic of Silver Bullet ricey start button
for what it`s worth l installed my first start button on a 280Z in 1990,before all the ricer hype.l love start buttons,they`re a much more satisfying solution to engaging the starter then the ol' key.l looked for an appropriate surplus aerospace button switch for quite some time,and l considered several arcade machine switches but the S2000 unit was such a smooth install it looks like it was born there..
I like it, so can I ask how much it cost? Where did you get it?
I may just copy you, thanx
Thom '81 SC Euro Money Pit #1 '02 Boxster S "Econo Car" (or at least thats what I told the wife) |
Hope you don't have an emergency
. Clean install - nice job.
Chris M 1985 911 Carrera w/ 3.6 |
Looks good! - did you 'need' to do this?
My ignition switch occasionally doesn't want to move to the start position and takes a few resets to off before moving against the spring into the start position. So this would be a way to avoid a new switch if the problem gets worse (or strands my wife once). Pleae provide details on source and install (size hole, wiring tricks) Is there anything to prevent you from starting while the engine is running?
75 911S Targa - Mine from 2001 until sold to Germany buyer 10/2016 <ALL DIY> Brakes/Wheels '01, Body/paint/restoration 7/04, Suspension 3/07 Engine rebuild - done 7/08 - added 28 tube cooler and SSIs - running strong. Ducktail painted. 2021 MachE, 2012 Outback, 2019 Crosstrek, 2018 Impreza wagon |
Go Gators!
That's a great, clean installation and I'd encourage everyone to personalize their cars in whatever way makes them happy.
But... What's the big deal about separate starter buttons? Every time I read a car magazine, someone's exited about "hitting the start button on the new Lambomartinferrarentley" and how different this seems. My grandfather's 1950 Pontiac had a separate button, as did almost every preWWII car. Seems to me that putting in the key and turning it, is just one step, instead of two. I like my '03 Tundra (and a growing number of other imports) that have the "bump and go" feature-- turn the key to "start" just briefly and let it go, while the electronics trigger the start circuit just long enough. Maybe we should bring back chokes and manual ignition advance--that'll get the hacks really writing. Or maybe I'm already becoming the curmudgeon that I know I'll be someday.
Timothy Stoops Air '62 356 B-‘86 911 Cab H2O '12 Cayenne |
thanks guys.You can save big $$$ by buying from http:// www.handa-accessories.com,a great import parts source.$35.00 !! and for the wiring instructions go to http://www.miata.net/garage/pushstart/ as for the mod being needed,no but l feel like a spaceman blasting off when l "ENGAGE "!!!with the starter button. l started with a totally stock, near concours 84 3.2 Carrera eight years ago and virtually NONE of the mods l`ve done to the car have been "needed".The 84 3.2 is a pretty nice car when it`s stock,and mint.The Porsche driving experience begins upon starting the vehicle,and this particular mod is a button pusher for me
my life begins at 150MPH Last edited by raceman; 06-01-2004 at 07:38 PM.. |
How does this work - put in the key and turn and then hit the start button?? What about your flashers Or what was in the hole before that? My flashers are there.
I think this is very cool. Especially if you could eliminate the key - I guess thats a theft problem.
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
hey EW,yeah l just removed the flasher swith and installed the S2000 switch,it`s that simple.The S2000 start button is the perfect diameter but you`ll want to file off a couple of areas on the switch body for a perfect pressure fit in the dash.As for the hazard switch l plan to relocate to the right side of the steering column in an unused factory location.This procedure will require fabbing a harness to extend the factory one that won`t reach over there.The like on the original post provides enough info to get it wired and to do it right using a relay.l`ve got mine set so the key won`t start the car anymore.l like the theft protection of the steering lock though so l`m keeping all the other key functions
Having a seperate start switch makes sense for us car guys.
First, if you have a hi comp engine, sometimes its easier to get the engine turning over at speed, then adding spark. And sometimes it's nice to crank the engine when you're working on it without ignition.
Jake Gulick, Black Rock, CT. '73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B] |
