-   -   My speedometer needle "squacks and quacks" like a duck...no kidding. (http://forums.pelicanparts.com/porsche-911-technical-forum/165766-my-speedometer-needle-squacks-quacks-like-duck-no-kidding.html)
H.G.P. 06-01-2004 03:40 PM
Well I drove the 911 about 60 miles distance today, and something I've had ever since I bought the car I thought I'd mention. The speedometer, which fluctuates, (but is accurate when steady), often makes a "squack, squack" sound as the needle moves?
Anyone have a clue on this one?
Thanks.
scottb 06-01-2004 09:50 PM
If it walks like a duck, and sounds like a duck......:D
ValveFloat 06-02-2004 07:53 AM
:) Mine does that too. It got worse and worse to the point I had to disconnect it. I have to assume something inside is worn or broken, and the speedo needs a rebuild.
doozer 06-02-2004 07:58 AM
Its calling out for the addition of a duck tail....
Grady Clay 06-02-2004 08:06 AM
Disconect it at the transmission so it doesn't damage anything.
Send the speedometer in for inspection and repair.
Check out the speedometer cable for smothe operation.
Reinstall, reattach, enjoy.
As easy project.
Best quack,
Grady
xlr8 06-02-2004 10:28 AM
http://forums.pelicanparts.com/uploa...1086200833.jpg
:D
joehahn 06-02-2004 11:01 AM
fellas, i just replaced my speedo cable. still fluttered. friendly pelican responded to a private message and told me to spray wd-40 in the speedo, which i did. stopped the chatter AND now new cable + wd-40 = no more bounce or chatter.
joe 68 L
and joe, we have the same car! yours looks awesome, if i get $$$ together for paint think i'll make the jump to yellow!
Lorenfb 06-02-2004 11:29 AM
If you decide to have the speedo (or tach) serviced, call Pelican.
They have many vendors, some of which can repair your gauges.
ValveFloat 06-02-2004 12:02 PM
I wondered about doing that. Any particular place to spray in the lube?
Thanks! L's are cool, yellow L's are really cool. ;)
joehahn 06-02-2004 12:13 PM
climb in trunk, undo cable at speedo, point tip in and spray away. drive a bit, do it 2 or 3 times (plug cable in drive, etc) and problems will be solved. or not.
