LinkBack | Thread Tools | Rate Thread |
Well I drove the 911 about 60 miles distance today, and something I've had ever since I bought the car I thought I'd mention. The speedometer, which fluctuates, (but is accurate when steady), often makes a "squack, squack" sound as the needle moves?
Anyone have a clue on this one? Thanks.
1969 911 E Coupe "Little Bull" "Horse" "H." Heart, "G." Gears, and "P" the Porsche |
If it walks like a duck, and sounds like a duck......
1984 Targa |
Mine does that too. It got worse and worse to the point I had to disconnect it. I have to assume something inside is worn or broken, and the speedo needs a rebuild.
Joe 1993 C2 |
Its calling out for the addition of a duck tail....
Thanks Todd I drank what? = Party out of bounds - PriceLESS - BudWIZER "Boy Im gonna burn you a new one! - A new what officer?" = night in jail 993'ish Widebody bastardo http://hypertec.ws/todd_porsche/photos/
Disconect it at the transmission so it doesn't damage anything.
Send the speedometer in for inspection and repair. Check out the speedometer cable for smothe operation. Reinstall, reattach, enjoy. As easy project. Best quack, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
On a great circle route
Russ |
fellas, i just replaced my speedo cable. still fluttered. friendly pelican responded to a private message and told me to spray wd-40 in the speedo, which i did. stopped the chatter AND now new cable + wd-40 = no more bounce or chatter.
joe 68 L and joe, we have the same car! yours looks awesome, if i get $$$ together for paint think i'll make the jump to yellow! |
If you decide to have the speedo (or tach) serviced, call Pelican.
They have many vendors, some of which can repair your gauges.
Have Fun Loren Systems Consulting Automotive Electronics '88 911 3.2 '04 GSXR1000 '01 Ducati 996 '03 BMW BCR - Gone Last edited by Lorenfb; 06-02-2004 at 07:07 PM.. |
Joe 1993 C2 |
climb in trunk, undo cable at speedo, point tip in and spray away. drive a bit, do it 2 or 3 times (plug cable in drive, etc) and problems will be solved. or not.
