Irrationally exuberant
ChrisBennet's Avatar
Getting gasoline smell out of concrete?
I spilled some gas in my garage a while back and I can't get rid of the smell. I washed part of the floor with detergent but I'm not sure where else in the garage I might have spilt it.
Any tricks for detecting gas spill areas and removing it?
Sorry if this is off topic but it is serious enough to make my garage unusable (for working on Porsches!) with the door closed.
thanks,
Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 06-02-2004, 04:57 AM
Throw a match on it!
Old 06-02-2004, 05:26 AM
Smart answers aside, gas is a volatile liquid and I would expect it to dissapate with alot of air flow. Open the door and run a fan for a day would be a start.
Old 06-02-2004, 05:27 AM
I spilled this a few weeks ago. It is faint enough that I can't locate the spill with my nose but if the garage has been closed over night it really reeks. The gas I spilled on my wooden bench seems to have evaporated (i.e. you can't smell it).
Perhaps the lawn mower is leaking?
-Chris
Old 06-02-2004, 05:32 AM
perhaps the lawn mower has a carb ? carbs stinky poo
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 06-02-2004, 06:14 AM
Perhaps the use of a cleaner that will break down the petroleum base. Maybe a Citric based cleaner. They selel the industrial strength stuff at Home Depot by the gallon for about $10.
Warren & Ron, may you rest in Peace.
Old 06-02-2004, 06:40 AM
rcm rcm is offline
rcm's Avatar
Hey Chris...funny you should mention the lawnmower. I had a generator in the garage under the house. I started to get faint wiffs of gas but, could not pinpoint it. It got worse and worse. What i found was the gas was gravity feeding into the carb on the generator. There is a 15 gallon tank on top. The air filter was sponging the gas just enough so you could not find a leak. But, it was holding enough gas to stink us out.
Rick
" too many people spend money they haven't earned to buy things they don't want to impress people they don't like" Will Smith
Old 06-02-2004, 06:41 AM
The smell started after I fixed the lawn mower. I didn't use new gaskets on the carb so perhaps the gaskets are leaking. I'll make the lawn mower sleep outside tonight and see if that makes a difference.
-Chris
Old 06-02-2004, 06:58 AM
Zeke's Avatar
Bleach.
Old 06-02-2004, 07:33 AM
Friend of Warren
Chris, I would seriously be looking for something leaking gas. I have spilled gas in my garage a number of times and the smell always dissipates in just a day or two.
Kurt V
Old 06-02-2004, 07:48 AM
Certified Pre-Owned
BGCarrera32's Avatar
Send your cat out there to pee on the concrete...outta take care of it.
'84 Carrera Coupe
Old 06-02-2004, 07:49 AM
I think you've hit the nail on the head. Thanks.
-Chris
Old 06-02-2004, 07:57 AM
Last time they did that I had to swab the floor down with Swepco to get rid of the smell.
-Chris
Old 06-02-2004, 07:58 AM
Mystery solved! I left the lawnmower outside last ngiht and this morning the garage just had the faint aroma of Swepco. Thanks guys!
-Chris
Old 06-03-2004, 07:07 AM
