-   -   If it isn't broke, don't fix it...I should have listened!!! (http://forums.pelicanparts.com/porsche-911-technical-forum/165818-if-isnt-broke-dont-fix-i-should-have-listened.html)
Padrino 06-01-2004 09:19 PM
My '70S 2.2 with webers was running like there was no tomorrow. Sputtered one day and my local wrench (Black Forest) tol me to check the idel jets.
I took them out, cleaned them and it ran like it's old self again. However, I noted that 2 of the jets were of a different size, .045 inlieu of .050 as the other four. Smart me decides to buy all new ones at the .050 size. I get the 6 of them along with new rubber o-rings, install them and....it runs like crap now. Nothing else changed. I've even gone back and put in 6 other o-rings just in case.
What the %$*&&@!) is going on?????
Ken
john walker's workshop 06-02-2004 08:40 AM
put in some fresh plugs and readjust the mixture screws. if you change idle jet size, the idle mixture changes as well. use a plug that is hot enough to stay clean.
911ctS 06-02-2004 11:19 AM
also, did you physicaly messure the idle jets? people have been known to drill out smaller jets to make complete sets. could be that your two 45's were drilled at one point out to 50. just a thought.
Wayne 962 06-02-2004 11:21 AM
You really can't adjust these carbs without one of these:
http://www.pelicanparts.com/catalog/shopcart/MISC/POR_MISC_INNOVT_pg1.htm
-Wayne
Padrino 06-02-2004 11:46 AM
Hey Johnny Walker...
Yes, did a complete tune up with new plugs (NGK), wires, dizzy cap, innards, etc. just before I changed the jets.
Original two .045 jets looked like they might have been taken out to .050's but couldn't confirm. Regardless, going to all new .050's all around I thought should have just made sense.
Why the sudden change? Am I getting air around the new o-rings????? I've double the o-rings and it really runs bad, must be the jet's nozzel is pulled out that hair too far. Even without a double o-ring, the thing seems to be running very rich now as there is a smell of gas and it's smoking. Even rechecked the dwell which is dead on 38 degrees.
I've set tomorrow afternoon aside to tweak this thing again but I'm getting frustrated at this point.
Ideas anyone????
Padrino 06-02-2004 11:49 AM
Wayne,
NICE tool. Have to wait until I rob the kid's piggy bank to buy one though.
What ever happened to a piece of rubber hose; one end in the carb the other in your ear??!!!
Padrino 06-02-2004 12:53 PM
bump
Evans, Marv 06-02-2004 03:44 PM
Ken:
Everytime I've heard of somebody doubling up on "O" rings, it has caused problems. I haven't played around with those in Webers, but stacking up "O" rings doesn't usually make sense. Maybe it does in this case. Try a search to see if you can find out anything. Otherwise, bump, bump, bump!
Zeke 06-02-2004 05:30 PM
http://jm.g.free.fr/smileys/huh.sml.gif If they were drilled out to 50 and he put new 50s in there...........:confused:
raceman 06-02-2004 06:18 PM
whenever this happens to me(l`ve got 12 vehicles,this stuff happens all the time)l put things back as they were before l "fixed" it.l`d lose the extra O rings also.
911Mac 06-02-2004 06:26 PM
Have you tried putting the original jets back in? If you do and the engine runs as it did before, then there's something different about the new jets. Might give you a little more information to go on.
Padrino 06-02-2004 07:42 PM
I've got the original .050's but trashed the .045's as they looked pretty corroded. Also, dumped the orginal o-rings.
Plans for tomorrrow called for putting the 4 original jets back in but this is kind of like Russian roulet with only 4 of the 6. I've looked at the new jets and they are idenical to the original in size, lenght, etc.
I'm really at ends on this one. As nothing else changed except the jets and the o-rings. It just doesn't make any sense....but then I've come accept that about most things these days.
MY83SC 06-02-2004 07:58 PM
Buckle up and take it to your local wrench. Have them check the mixture, etc.
Padrino 06-02-2004 08:22 PM
Mike,
Just what the wife said; take it to the mechanic. Can't give in to her, it's a guy thing I guess. I've got to figure this one out on my own....with lots of help from this BBS! It looks like it should be a simple fix but ????? I'm not sure it's just the mixture, why would it be if it's only the jets were all replaced with new ones of the same size. Doesn't make sense.
Ken
Zeke 06-02-2004 08:29 PM
Yeah, it's a guy thing alright. Who's gonna tell us we can't sort out just a stinkin' little carb?
I know that's how I felt just before the engine seized at the track. http://jm.g.free.fr/smileys/hehehe.gif
Padrino 06-03-2004 09:35 PM
everyone's advice was right....put the old parts back in and see what happens. The beast is running as good as it ever did again!!!!!!
I did a bit of dumpster diving to find the .045's I'd tossed. Found 'em!!!!
Pulled the "new" .050's and did a comparison between old and new. Very interesting. Although I don't have a "guage" to know the exact size, I did use a sewing needle to see how much of it would stick out the small end of the nozzel. Surprise, on the old ones the needle stuck further out. Given the needle's tappered it tells me the jeting in the old ones are actually larger than the new .050's I bought (all $65 worth of them!!!:mad:)
Also on the older jets the other 2 holes further down the shaft of the jet ( I have no idea what to call these so for now I'll just identify them as the other 2 holes) are also larger than the new jets.
I guess some wrench had enlarged the old jets beyond the .050 size. Trouble is the needle was sticking out further on some then others of the old jets so they are not all the same size.
How do I go about finding out what size the "old" jets actually are? Is there a guage or something out there I can get my hands on to do that?? Once I do and find the size (of the biggest one I suspect) how do I reemout the new ones to fit the same size? Or do I just go for another $65 and buy new ones at a larger size?
Input please!!!!!!
Ken
project 911 06-04-2004 05:53 AM
Ken,
I think our good friends Motor Meister have a kit for sizing and reaming jets, although I can't find it on their site. You might give them a call.
www.motormeister.com
911ctS 06-04-2004 09:07 AM
Ive seen just about every combination of marked "this" and measured "that" jets possible. Especially if you buy them at swap meets. When you drill a jet its very hard to get it to the desired size. So if he had two 45's drilled out to 50 then I would bet 9 times out of 10 that those drilled 45's are going to actually measure larger than his 50's. Rule of thumb if your gonna drill you've got to do it to all of them, and you've got to start with the same base.
911Mac 06-04-2004 04:00 PM
Ken,
Here's a link that mentions how to resize jets and what you need to do it.
url http://www.factorypro.com/tech/Choke_jetting.html/url
-Mac
911Mac 06-04-2004 04:01 PM
Ken,
Sorry try this:
-Mac
Padrino 06-04-2004 04:19 PM
Mac and Steve,
Good input from you both. THANKS.
I've now called Ray at Motor Meister. I'm going to crawl into the carbs and get the sizes of all the jets immulsion tubes and the venturi's. Ray will give me the actual's of what I should be running given the engine, ignition, my location and how I want to drive it (crazy last question...FAST). Then he'll sell me what he thinks I need for the right setup.
Stoddards used to do this service years back but when I contacted them they said "webers??". Must be a sign of the times.
For now, the P-car's running back to normal, all the way to redline. Just would like to have it set up right all the way around. Hey for a 34 year old car and a 55 year old driver, nothing's working exactly perfect anymore.
Ciao,
Ken
