-   -   CIS - What Is Does This Screw Do? (http://forums.pelicanparts.com/porsche-911-technical-forum/165893-cis-what-does-screw-do.html)
Porsche_monkey 06-02-2004 11:15 AM
In the middle of he picture attached is an adjustment screw with a spring behind it. What does it do?
http://forums.pelicanparts.com/uploa...1086200141.jpg
vash 06-02-2004 11:17 AM
air bypass. it affects your idle speed.
Porsche_monkey 06-02-2004 11:18 AM
Which explains why my idle speed changes when I tweak it. Thank-you.
Rondinone 06-02-2004 04:28 PM
That's the only way you should adjust idle speed. The stop setting on the throttle valve should never be touched. Youre idle speeds will be inconsistent if you try to adjust the throttle valve stop.
