Slumlord
Porsche_monkey's Avatar
CIS - What Is Does This Screw Do?
In the middle of he picture attached is an adjustment screw with a spring behind it. What does it do?
Old 06-02-2004, 11:15 AM
vash's Avatar
air bypass. it affects your idle speed.
poof! gone
Old 06-02-2004, 11:17 AM
Slumlord
Which explains why my idle speed changes when I tweak it. Thank-you.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 06-02-2004, 11:18 AM
Who is John Galt?
Rondinone's Avatar
That's the only way you should adjust idle speed. The stop setting on the throttle valve should never be touched. Youre idle speeds will be inconsistent if you try to adjust the throttle valve stop.
'79 911sc Targa
'02 slk230 kompressor
'84 Tamiya Falcon
A democracy cannot exist as a permanent form of government. It can only exist until the voters discover that they can vote themselves largesse from the public treasury. From that moment on, the majority always votes for the candidates promising the most benefits from the public treasury with the result that a democracy always collapses over loose fiscal policy, always followed by a dictatorship. The average age of the world's greatest civilizations has been 200 years.
Old 06-02-2004, 04:28 PM
