Transmission fluid change (success!!!)
Just changed transmission fluid for the first time, no problems. ('86 Targa). The old stuff was blue and smelled like garlic, according to my wife. The new is Kendall 80W-90, special for limited slip gears, and doesn't smell like garlic. Purchased from our host, along with the requisite 3/8 inch drive, 17mm hex wrench.
This is very subjective, but the car seems to shift much easier than before. Especially the first to second pull, which seems to take less effort. Anyway, a datapoint for everyone; the Kendall works well for me.
Member 911 Anonymous
Outstanding, you will need to do one more change in 500 miles to flush the old stuff out.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Why the change at 500 miles? Is the blue garlic stuff that radioactive?
Any gear lube will leave residue, but it's up to you, I did it 3 times, Dr. Zimmerman said twice was enough. I have a bit of OCD, sorry.
muck-raker
FWIW, that old blue garlicky stuff was probably Swepco. I've been reading with interest how guys with 915 trannys have had success with the Kendall stuff. It seems to be getting more popular.
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
steeler1
Transmission fuild change
Can you explain how you did it I'm wanting on a manual that I ordered (Wanyes) but I'm curious if you used a pump to refill and how hard was it to do the job How long did it take Thanks
YEA!
as for filling - you can get a hand pump at any auto parts store for ~$10 - then since some oil comes in Qt's and the stupid cheap pump no fit the Qt bottle - i use a cleaned out 1/2 gallon milk (plastic) jug - the pump fits perfectly! and I found with the azz jacked up a little (lower as much as you can when filling) that it gets full enough - I took mine to a 4 post lift to check how much I was "short" and it was perfect - just starting to overflow the fill hole
Ed M 86' Coupe |
Jack up the rear end and place a couple jack stands. First, remove the fill plug. I had to use a small breaker bar. Have a drain pan under, as I had some dripping. Now remove the drain plug and watch the old goop come out. Replace the plug, insert the pump hose into fill hole and pump until you see overflow. Replace fill plug. That's about it. All items purchased from our host ... pump, hex socket, fluid. I poured the quarts into a 1 gallon milk jug that fit the pump. First I poured out the milk ![]() Who knows, maybe some cow juice would improve shifting!! |
Banned
While I was removing the fill plug, I boiled some water on the stove. While the trans was draining, I put the four quarts of Kendall in the boiled water, which was still really hot. After the trans had stopped dripping, I took the four quarts and dumped them into my gallon jug, and started pumping. The pumping goes a LOT faster when the oil is hot (and thus less viscous). |
Check the marine section for the pumps.
Peppy 2011 BMW 335d 1988 Targa 3.4 ![]() 2001 Jetta TDI dead 1982 Chevette Diesel SOLD
