What's the best way to clean fuse contacts?
I am in the final stages of my 74 911 restoration and the contacts for the fuses in the fuse box are corroded and need cleaning.
Has anyone found a good way to clean the fuse contacts, either mechanically, manually or using chemicals?
PorschePilot
74 911S Targa - High Quality 2.7 Rebuild and Full Body Restoration
MID9 Member
Beechcraft V-Tail Bonanza
(Fly'n high and low)
Old 06-03-2004, 12:17 PM
Detached Member
Hugh R's Avatar
Emery paper (fine) and electrical contact cleaner spray from Radio Shack work well for me
Hugh
Old 06-03-2004, 12:19 PM
I'd typically say fine sandpaper but leaving fine scratches only invites deep seated corrosion in the future. How about using an inexpensive, supermarket metal cleaner/polish called Noxon. Dab a bit on, let sit for a few minutes and wipe. It should leave the contacts like new. It works mostly by chemically disolving the oxidation.
Warren & Ron, may you rest in Peace.
Old 06-03-2004, 12:26 PM
The metal cleaner sounds like a good way to go. Thanks, I' ll give it a shot.
PorschePilot
MID9 Member
Old 06-03-2004, 12:35 PM
Senior Member
Jdub's Avatar
Also consider a pencil eraser. They are useful where the corrosion is not *too* bad.
John
'78 Targa in Minerva Blue
Old 06-03-2004, 01:10 PM
