Math guys: Question on seat belt strength
As I research the replacement of my 911 seatbelts I have a question regarding breaking force for the belt webbing material.
According to the DOT specs (FMVSS-209) the breaking point must be at least 26,689 N (Newtons). Does this translate to 5,999 pounds of force? Is this the same a tensile strength? This is the terminology that the webbing material manufacturers use. Thoughts?
Warren & Ron, may you rest in Peace. |
5,999.925903 # is a little closer
LOL...good one.
Same as Tensile strength?
Author of "101 Projects"
One thing to remember - never buy used belts, unless you know specifically the history of the car they came out of. Belts are designed to stretch on impact, and if they were taken out of a wrecked car, then they are no longer useful (one-time use, like airbags).
Buy new ones for safety. -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
My car has bucket seats and racing harnesses. I assume these are better for zipping around the track, instead of seatbelts, but how am i going to fare if I get in a head-on collision?
The DOT is very specific with stretch characteristics as well. These specs are given by the webbing material MFR in addition to recovery specs. My Strength question is to insure my info is 100% accurate. BTW, If I purchase new belts must I buy the entire mechanism as well? A mouse chewed into my existing belts.
"C-Rations"
Good point Wayne! That's kinda what I was thinking.
John The Stable: 1985 Carrera Cabriolet (RoW) Sold 2002 Chevy Tahoe LT (The Wife's) 1999 Chevy Silverado (Parts Hauler) 1969 Volkswagen Beetle (Purchased From Original Owner) I'm slower than the guy in front of me, but faster than the guy in back of me. |
Tensile stress...in Mechanical engineering terms ( careful...don't know how the belt manufacturers quote or use tensile strength)...is that load that begins to tear the fibers of the host material apart. I suspect that is what they mean. It is likely the point where the belt has taken on a permanent ( and non-recoverable) stretch...or has gone beyond its elastic limit. Contrast this with ultimate stress where you go even further and the belt arctually breaks apart in two or more pieces.
Unknown use of words..or assumed semantics..is dangerous in cases like this. I'd contact a manufacturer and ask if they mean its the point where elastic deformation has been exceeded, or when it "breaks". There is a difference ! ---Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Wil, Thanks for the info. Feds make it clear that breaking point is at 5,999 lbs. I'll let the manufacturer translate for me.
BTW, if I decide to use my "homemade" belts I probably won't share the info as it could introduce unwanted liabilty issues.
On a similar note, It seems advisable to replace belts on an older car. My '81 has never been crashed, but the belts are looking a little fuzzy and tired, probably like most of yours. Anyone done this as a preventative measure, or, alternatively, has anyone seen how older belts hold up in crashes?
TIA
Andy |
Andy,
One of the required tests (micro organism attack test) for belt manufacturers is to bury the web material in soil for two weeks and to retest for breakage. Another is to cut 10% into the belt and test. No mention of effects of aging. A very good point.
That's interesting info, Rick, thanks. Might not be a problem, but although my belts appear to be made in the same way as the belts on a new car, the definitely don't look as fresh (and they aren't).
Andy |
Yes seatbelt webbing degrades over time. The stitching on seatbelts is very tightly controlled and it is not adviseable to sew your own. I would be very cautious of buying webbing from anyone. Personally this is one of those things that I think is worth spending the money for at the dealer. They are just not worth messing around with.
Racing belts hold you much tighter and actually put additional forces on the body because they slow you down faster as there is less stretch, but they are stronger and will hold you tighter so you are less likely to hit the steering wheel or windows or whatever. Thanks Mike
1972 911T Targa 1994 Volvo 850 Wagon 1988 BMW 635 CSi |
