Find the leak
What is the best way to find a vacuum leak? Upon returning from a two week vacation I started up the porsche and for the first 10 to 20 seconds it had a good idle and then all of a sudden it would miss and backfire. I had to feather the throttle to keep it running.
After warm up it still ran rough. checked the vacuum and guage read about 10 inch hg. Shouldn't it be a bit higher? Is it wise to spray carb cleaner around areas to find leak? It's a 1983 SC Thanks for any help bk |
Slumlord
Use either quick-start (spray it on the hoses) or an unlit propane (or acetylene) torch. As the gas is sucked into the engine your rpm will rise.
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
Thanks the torch seams like the way to go
bk |
