Padrino's Avatar
Question bouncing tach
Dwell's dead on 38 degree on my 2.2S. The tach has taken to bouncing of late. Will jump up to 8k when doing around 4k. All over the place. Any ideas? Car has permatune blue with 6 pins, running webers. Was fine forever and just in the last weeks taken a mind of its own.
Ken
Old 06-03-2004, 10:58 PM
D Hanson's Avatar
I just like to think my ebgine revs so quickly that the tach has a hard time keeping up. It does seem this way in the sweet spot.
90 C2 Cab Ruf Red/Blk
03 Caynne S L.Blue/Grey
03 996 TT Blk/Blk
04 996 Atlas Grey/Blk
Old 06-03-2004, 11:31 PM
rotorhead's Avatar
I had the same problem on my 88 930, check your voltage regulator by measuring the voltage across the battery terminals with the engine running. It should read read around 14v if it is higher than this then replace the regulator and it should fix the tacho bouncing.
2008 BMW 320i
2006 Mercedes ML320
2004 Mercedes ML270 cdi
1998 Porsche Boxter
1988 Porsche 930 Targa (sold)
Old 06-04-2004, 01:28 AM
On the early cars this is sometimes traced to the points; check your timing and dwell. Jim
Old 06-04-2004, 06:28 AM
Ditto that, check/replace the points- I had a similar problem, but not the same.
I was told that the RPM's are taken off the points, not an actual reading of the engine. If the tack acts up it's sometimes the points.
Old 06-04-2004, 06:44 AM
Padrino's Avatar
voltage is perfect at 14v. just had new gen/reg installed.
dwell is dead on at 38 degrees.
next????
Ken
Old 06-04-2004, 08:47 AM
Padrino's Avatar
next????
Ken
Originally posted by Padrino
next????
- change the good points to another good set.
- check 2 into 1 tach connector in harness, on left side of engine comp
- borrow a friend's good coil and CD to confirm yours is ok
- tachs have an internal spring that wears out.
- borrow a friend's tach to see if problem stays or leaves.
I assume the problem was there before you changed alternator. A presumably good alt and reg can cause a tach problem. Don't forget to report your success.. eventually.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 06-04-2004, 10:52 AM
You would be surprised what a faulty ground strap can do. I would check all of them.
2002 C2 Cab, 1982 sc, 1978 sc, 1976 s,1985.5 944, 2003 Honda Pilot, 2001 Volvo X/C 70, 1977 FIAT 124 spyder (an abarth someday), 2 1984 Vanagon Westis
1958 BugEye Sprite, 1960 BE Sprite, 1978 Yamaha XS11 1970 Honda 750 K0, 1982 BMW R65RT, 1997 Duc 916
Old 06-04-2004, 11:05 AM
Randy Webb's Avatar
sometimes caused by a CDI box
as well as the points, coil, V. reg., or ground straps...
Old 06-04-2004, 02:41 PM
braddb_82SC's Avatar
Check your spark plug wires. Last time this happend to me I traced the problem to corrosion where a connector contacted a plug. I pulled the connector off the plug and cleaned it with some sand paper. The bouncing tach settled back down.
Another time it was due to a bad alternator or voltage regulator (integrated on my '82 SC). 24 hours after the onset of tach bounce the car stranded me on the side of the road due lack of electrical power. My battery was no longer charging. A new alternator solved the problem.
-Brad
'82 911SC Coupe
Old 06-04-2004, 03:06 PM
Someone told me that there is a ceramic/porcelin ground connection that sometimes cracks causing many funny problems. It's located in front of the driver on the otherside of the firewall.
They said:
I had an electrical problem couldn't figure out what was causing it. There is a wiring harness on the fender wall directly in front of the driver. The ceramic posts had cracked and was causing a short.
Note: Seems like even good points aren't good enough for long on my car- going pointless by the end of summer.
Old 06-05-2004, 03:04 AM
