Angry trans. problems
have a 1970 911 took out for first time went about a 1/4 of a mile, then came out of gear at stop sign and could not get into 1,2,3 or R, like it jamed or shifter is stuck? I can get into 4 and 5th is the tran. gone? any idea?? thanks mark
Old 06-15-2004, 03:46 AM
Check the shift coupling under the plate on the floor behind and between the seats. It may be loose or the plastic bushings in it are bad. Jim
Old 06-15-2004, 08:51 PM
