gb0 gb0 is offline
Speedo Problem Need Help!
I just finished changing out the gear to fix my odometer, the speedo was working prior. When I start up the car the speedo shoots up to 150 and stays there. Any idea what would cause this? It is a VDO gauge from 1983 911sc. Any suggestions would be appreciated.
Thanks,
Gerard
Old 05-21-2004, 07:22 PM
Banned but not out, yet..
RSBob's Avatar
Take it apart again and double check everything
Old 05-21-2004, 08:51 PM
MY83SC's Avatar
And this must be why 911's look fast, even when still!
Mike
83 SC
Old 05-21-2004, 09:47 PM
Send a message via AIM to fintstone
I suspect you have swapped the sensor wire with another on the back of the gauge.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 05-21-2004, 11:04 PM
gb0 gb0 is offline
When I took it apart I made a connection diagram. Kind of hard to mess up that way but just in case. There are ony three wires to connect: power to + ground to - and sensor wire goes beside the ground terminal, I dont't remember the gauge marking off hand. This does leave one connector on the guage with nothing attached to it. The gauge is electronic. Any more suggestions? Does the bentley repair manual cover guage troubleshooting?
/Gerard
Old 05-22-2004, 04:02 AM
From an earlier thread:
Looking at the back of the speedo, the group of multiple terminals at the right side of the gauge are, from left to right:
two brown wires andone brown with red stripe
one brown wire with red stripe
one red/white wire and one brown/black wire
one red/black wire and one red/blue wire
The bulb socket at the bottom gets the bulb with the black/blue wire.
The bulb socket at the top on the right gets a bulb with a black/blue wire.
The bulb socket at the top on the left gets a bulb with a white/green wire.
At least that's how it is on an '83 SC.
Old 05-22-2004, 09:06 AM
gb0 gb0 is offline
Well the the saga continues. I found a trace on the board that was lifted and broken so I ran a jumper. It also looks like I have a blown resistor and this is where I need some help. I need the value of the resistor that is closest to the 12V lead wire on the speedo pcb. The colors are gold / something / something / orange. Does anyone know what this is supposed to be?
Thanks,
/Gerard
Old 06-06-2004, 01:08 PM
Lorenfb's Avatar
Send to Pelican. They have suppliers that can repair it and calibrate it.
Why risk damaging it further?
Have Fun
Loren
Systems Consulting
Automotive Electronics
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 06-06-2004, 01:24 PM
