Randy Webb's Avatar
Here's something that ought to be made out of Al
Accurate wts. in lbs.
915 style transmission support bare (bare), w/shim 3.7
915 style trans.support complete w/ rubber mounts, through bolts, etc. 6.0
Anybody know how much the 964 style mount weighs? It's Al.
Old 06-05-2004, 09:52 PM
Porschekid962's Avatar
Send a message via AIM to Porschekid962 Send a message via Yahoo to Porschekid962
why not get crazy and build the trans case out of rfcc??? mclaren is using that this year in F1. pretty insane stuff, maybe after i win the lottery.
74 911s neverending story. two feet and a jetta for now.
Old 06-05-2004, 10:00 PM
If the design of a part is governed by stiffness (flexing and deflecting under load) then switching from steel to aluminum may not be warranted as although aluminum is about 1/3 the weight of steel it is also only 1/3 as stiff. One may be better off optimizing the steel part but this can drive up manufacturing costs. There are a lot of tradeoffs both technical and economic. Cheers, Jim
Old 06-06-2004, 10:39 AM
Randy Webb's Avatar
Right, Jim. Then there's Ti. But ever since I saw a 964 version on eBay it occurred to me that PAG already did the analysis needed re flexure.
Someday I may try to modify the 964 Al piece. It is not a huge amount of wt. and is in about the best possible spot to have wt. but....
Old 06-06-2004, 11:11 AM
Ti's still only 60% the stiffness of steel; I know of an application (non-automotive) where substituting Ti for steel resulted in performance degradation due to the stiffness issue. Jim
Old 06-06-2004, 12:44 PM
Go Speedracer, go!
SpeedracerIndy's Avatar
Here's on on ebay. Only $55: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33733&item=2481312897&rd=1
1981 SC ROW Coupe
Old 06-06-2004, 02:13 PM
MT912RS's Avatar
Crummy pic.
Old 06-07-2004, 09:17 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Try one off of a 87-89 G50. It's aluminum/alloy too. Problem is, the mounts are not removable and it's beefy. So it's probably heavier than the 915 steel piece.
Kevin L
'86 Carrera "Larry"
Old 06-07-2004, 10:55 AM
Information Junky
island911's Avatar
Originally posted by Jim Sims
If the design of a part is governed by stiffness (flexing and deflecting under load) then switching from steel to aluminum may not be warranted as although aluminum is about 1/3 the weight of steel it is also only 1/3 as stiff. . . .
True, but many times the less dense aluminum will leverage thicker geometry for a much better weight specific stiffness. (ie an aluminum panel may only need to be 40% thicker to achieve the same stiffness as a steel panel. . .making the alum version weigh half as much)
(Not to imply Jim Sims isn't completely aware of this . . .just pointing it out for others benifit.)
I've also seen the "steel trans-mount meets hole-saw" story. . .a nice ending
Old 06-07-2004, 11:25 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Not to be confused with the "steel motor-mount crossbar meets hole-saw story" right? Which incidentally also has a happy ending, resulting in a "oooooh! You must race your car?" comment from the onlookers.............
Kevin L
'86 Carrera "Larry"
Old 06-07-2004, 11:46 AM
