"Cheap is expensive"
re indexed rear Tbar on first try
It seems the rear Tbars are a pain to adj. from what I have read. For a while now I have been learning about suspension and alignment. I realized the height of my car was off and figured out the rear was the problem. The height was off by approx. 1/2" and had a choice to either lower the rear drivers side or increase the passenger side. Since my car is mainly street and there was evidence of some scrapping I decided to increase the torsion rate on the passenger side. Thanks to a buddy out of town who figured out exactly how to adj. the T bar in 1/4" incriments I followed his advice and got it done right the first time. He was dead on and my height measurements were too. I even marked the control arm and hardware exact with no pre load when doing this and got everything back where it was. Strangely enough it was alot of fun, maybe I'm going crazy?
Brent |
when you tackle a job for the first time and nail it with no problems then it is fun.l hate to say beginners luck but l`m glad it worked out so well,people struggle for days just on disassembly sometimes.
my life begins at 150MPH |
If you didn't change the bushings, then it might not be that bad a job. For me, changing the bushings makes the work much more complicated. I have to go back and re-index since mine was off by 50 mm. I must have knocked the level out of whack. To adjust it, it shouldn't be any more than a two hour job.
1999 996 C4 Cabriolet 1997 BMW M3 (Hail) 1985 928 S (Sold) 1982 SC Targa (Sold) |
Ah, not beginners luck...the guy who knew how was why it went so easy. That is once I knew how much the height was off. Here it is, counter clockwise 2 splines on the inside and then clockwise 2 splines on the outside. Each set is approx. 1/4", cool huh?
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
Binge User
Thom beat me to it. That is what I used when I completely rebuilt my suspension & it worked perfect.
Paul |
Author of "101 Projects"
WooHoo!
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
This is the one job I keep thinking about doing myself but common sense tells me to leave it to my mechanic . Any tips or words of encouragement ?
Jim |
Senior Member
Jim:
If you mean replacing bushings, tbars, and repainting the spring plate and whatnot then yes, you can handle this. There is tons of information in the archives and you ought to put together a binder and go ahead and highlight the material that applies to what you want to do. I keep several very, very thick binders with information from this 'board. I have a single, smaller binder that I use for the "job at hand" for reference (a traveling binder if you will). John
'78 Targa in Minerva Blue |
Here is what I did, removed the rear drop link for the sway bar. Jacked up the side of the car and took the tire off. Scribed all hardware and the plate to the control arm so I know where everything was set. Took another jack under the control arm. Start to loosen the bolts (not the height adjust) and go slow so you can align the height of the control arm with the plate with no load. So when you take all 4 bolts off the plate is aligned with the control arm holes. Then remove the outer bushing cover with the 4 bolts. That cover will come right off and clean it up if you like. Then slowly work the spring plate out from the chassis and hopefully the Tbar will stay inside. This is already assuming you know how much the height is off and round to the nearest 1/4". For every 1/4" go one spline inside and outside like I mentioned earlier. Decide if you want more or less torsion and go for it. Once you think it's good you can measure between the control arm holes to the new position of the spring plate ones. It should be the difference you want or it's not set right. If so then using the jack under the control arm to align with the new position and start to bolt stuff down in the exact place you scribed. Still since the torsion rate was changed it will change the alignment x amount but it should be better to get it back where it was good before then not.
Goodluck |
Where does the torsion rate change if you don't change the T-bar?
Same, the splines must be equal or they wouldn't fit. It's the bar diameter that changes and the hollow ones will be even bigger to compensate for the hollow bar.
