Oh Haha's Avatar
Porsche Crest Alignment specs--911SC
Hey hey Fellas!
Sending the 911 in Thursday for alignment after lowering, what specs should I give to the shop? I am most concerned about the rear. My hieght now is 24" to the bottom of the rear fender.
I do not have any rubbing issues. Factory numbers would no longer apply, correct?
Thanks in advance,
Wayne
Might as well post a picture, too!!
Pacific Blue
Wayne
Old 06-13-2004, 07:49 PM
Pat S's Avatar
Factory numbers for caster/camber/toe should still apply. Is the car a daily driver, occaisional track car, etc? Depending on that answer you may want to change some things.
Pat
Current: 07 S4 Avant, 06 Volvo S60R
Sold: '74 911, 01 986, 93 Volvo 240
Old 06-13-2004, 08:11 PM
D idn't E arn I t
RANDY P's Avatar
I'm approximately your height. Try these settings - my car is a street car, this is what they set it at. Shop that set it up is probably the best in town -
Front
camber L -.8 R-.65 deg
caster L 6.46 R 6.64 deg
Toe L 2.7mm R 2.7mm
Rear
camber L -1.62 R-1.5 deg
Toe L 1.7 mm R 1.7mm
Full corner balance was also done before alignment, you may want to get that checked out and set to your weight.
I have NO problems with odd wear, tracks straight as an arrow, been like this for 24K and no issues. Probably time for a freshening. It's never driven better on these settings.
Good luck.
In the movies only bad guys sleep in king size beds.
Old 06-13-2004, 10:14 PM
