bigrubberjeep's Avatar
Had valves adjusted - Now there is noise above 5k RPM?
What gives?
85 911 SuperSport
No more looking! The jewel is mine!
89 Jeep Wrangler
A jewel in the rough
2000 Grand Cherokee
Family Wagon with Jewels on board
Old 06-10-2004, 12:37 PM
kstylianos's Avatar
Send a message via Yahoo to kstylianos
What kind of noise? Cat meow, bird chirp, tick-tick?
Charlie Stylianos
1982 SC Targa
www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles)
Old 06-10-2004, 12:39 PM
Friend of Warren
You must have one hell of a set of ears. I can't hear nothing but the roar of the exhaust on my 3.2 at 5k!
Kurt V
Old 06-10-2004, 12:50 PM
like tin rattling
85 911 SuperSport
89 Jeep Wrangler
2000 Grand Cherokee
B D B D is offline
B D's Avatar
Mine does the same thing at any RPM, sounds like a symphony consisting of six cylinders. JK
Above 5k RPM I am supprised you can here anything. If a valve is adjusted to loose you would here it at idle.
68 911L
Old 06-10-2004, 12:54 PM
"Now there is noise above 5k RPM"
...& this is a problem? My car is pretty noisy above 5000 too
Seriously, how loud is the 'rattling tin' noise? i.e. is it a oh-****-turn-off-the-car-immediately kind of noise or a hmmm-I-don't-remember-being-able-to-make-out-that-sound-before noise? Some posters have had valve adjustment nuts back off completely after an adjustment (& rattle around inside the chain covers) but I wouldn't expect a shop to make this mistake.
Old 06-10-2004, 12:58 PM
damn- I passed 911 posts & didn't even notice
Old 06-10-2004, 12:59 PM
I heard it when I was driving really close to a wall on my left (window Open)
It was the first time I went over 4.5KRPM since Valves were adjusted.
(I'm testing a new chip) .....wait a sec, could it be the new (to me) chip?
85 911 SuperSport
89 Jeep Wrangler
2000 Grand Cherokee
jluetjen's Avatar
Tin rattling -- could it be pingging???
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 06-10-2004, 01:01 PM
Describe pingging?
85 911 SuperSport
89 Jeep Wrangler
2000 Grand Cherokee
Old 06-10-2004, 01:03 PM
Originally posted by bigrubberjeep
I heard it when I was driving really close toa wall on my left (window Open)
Concrete walls have a tendency to intensify certain frequencies... by a HUGE degree. If this is otherwise inaudible I wouldn't worry too much.
Old 06-10-2004, 01:11 PM
Well - I havent heard it before (when driving next to walls) that is why it concerns me.
85 911 SuperSport
89 Jeep Wrangler
2000 Grand Cherokee
Old 06-10-2004, 01:12 PM
B D B D is offline
B D's Avatar
So true, on the freeway in the fast lane the median wall has played tricks on me before. As soon as I change lanes the noises are normal again.
68 911L
Old 06-10-2004, 01:14 PM
Maybe I'm just paranoid. I'll give it another spirited drive after work for the sake of research.
85 911 SuperSport
89 Jeep Wrangler
2000 Grand Cherokee
Old 06-10-2004, 01:19 PM
I would have my valves adjusted again. This time I would take my time and do it myself so it was done right.
Joe
Old 06-10-2004, 01:22 PM
Friend of Warren
Joe
Joe, what is the basis for this opinion? If he had loose valves you would be more likely to hear them at low rpm's as opposed to high rpms.
Kurt V
Old 06-10-2004, 01:25 PM
Motor sounds fine at low RPM and Idle (It purr's)
85 911 SuperSport
89 Jeep Wrangler
2000 Grand Cherokee
Old 06-10-2004, 01:30 PM
Friend of Warren
My guess either nothing or the tin around one of the heat exchangers which is the same as nothing.
Kurt V
Old 06-10-2004, 01:33 PM
Thanks Kurt - I'll keep my ear open
85 911 SuperSport
89 Jeep Wrangler
2000 Grand Cherokee
Old 06-10-2004, 02:00 PM
sithot's Avatar
Re: Had valves adjusted - Now there is noise above 5k RPM?
What gives?
How many miles on the engine?
Stretched chains, worn ramps will allow the tensioner to go nearly to full stop (even Carrrera Tensioners) and the chains do make a distinct noise although I'd suspect you'd recognize it for what it is.
Good luck,
Tom
R Gruppe #111
Early S Registry #235
res ipsa loquitur
Old 06-10-2004, 02:18 PM
