Moke81's Avatar
Unhappy Engine stuttered, stalled, stranded
Sun. 12:00 a.m. going to the hotel after an evening out, my 1981 SC ran fine all weekend long then it happened. First the engine stuttered, lost power, then stalled. I tried to start it and it almost turned over, but did not. Then it wouldn't start at all. It does crank. I kept trying to crank it, with no luck. I'm thinking it might be the fuel pump because when turning the ignition key, I can usually hear the fuel the pump run ... but I did not hear a thing. That's my only thought about what is wrong. Anyone out there who has had this problem? or know what it could be?
Old 06-13-2004, 02:17 PM
If your sure the fuel pump is not pumping first check the relay. Do you know how old the pump is?
1979 911 SC Targa
http://www.pelicanparts.com/gallery/Mike_Kast
Old 06-13-2004, 02:46 PM
fred cook's Avatar
Cool No fuel pump noise....
Step #1: Check the fuel pump relay fuse in the main fuse box. They have a tendency to overheat and cause the fuse holder to lose tension or corrode and build up resistance. Look inside the fuse cover to determine which fuse you are looking for.
Step #2: Take one of the black relays and swap it with the red relay. If the fuel pump relay is bad, swapping the relays will get you back on the road. Just be sure to buy a new relay as soon as possible.
Step #3: Put the car up on a lift and remove the tray under the front of the car. You will then be able to see the fuel pump. Using two pieces of 10 or 12 guage wire, connect the fuel pump directly to the battery to see if the pump is defective.
Actually, I'm putting my $$$ on the fuel pump relay fuse (#1). I had the same problem with my '80 SC and the fuse turned out to be the culprit!
Good Luck!
Fred Cook
'80 911SC coupe
Old 06-13-2004, 05:57 PM
JOT MON ABBR OTH
Groesbeck Hurricane's Avatar
One other question, what type of Ignition box do you have?
'83 SC Targa (sold ) MANLY babyblue honda '00 F250 7.3L (MINE!)
'15 F250 Gas (Her Baby) '95 993 (sold )
I don't take scalps. I'm civilized like white man now, I shoot man in back.
Old 06-14-2004, 10:52 AM
Virginia Rocks!
VaSteve's Avatar
Re: Engine stuttered, stalled, stranded
If you have an 81, have you tried the "open the air box and press up on the airflap trick"? If you hear the injectors scream, the fuel pump is working.
I had a similar problem, turned out I was getting only weak spark because my coil wire got loose and then the coil self destructed.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 06-14-2004, 11:08 AM
I also suffered the bad fuse problem. Don't be fooled by the fuse looking OK. Mine looked OK. Actually remove it, clean the holder tabs and insert a new one.
"Understeer is the sign of the Devil"
1989 911 Carrera Targa (Black)
2001 Jaguar XKR (Silver)
Old 06-14-2004, 11:15 AM
Moke81's Avatar
Ok, checked relay and replaced fuse I'm a bit confused because on the inside of the fuse cover it tells you what each fuse is, it says that the fuel pump fuse is 6 The Bentley shows it's 16 which one is it
Old 06-15-2004, 12:23 PM
Early_S_Man's Avatar
Porsche Crest
Spec book says #16 ... 25 Amp fuse.
Be sure to check the fuel pump relay socket with a bright flashlight ... to see if bubbled from overheating, contacts are corroded, or overheated and carbon-tracked!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 06-15-2004, 02:23 PM
Moke81's Avatar
checked relay socket looks clean. I can feel the relay clicking when turning the ignition.
Old 06-15-2004, 04:26 PM
Virginia Rocks!
VaSteve's Avatar
Try this. Turn key to "on" Open airbox and press up on airflap for about 5 seconds. You should hear the fuel injectors squeal. If you don't your Fuel Pump is bad.
Old 06-15-2004, 05:24 PM
JOT MON ABBR OTH
Might it not be spark related, not fuel?
Of course, mine started out as a fuel issue. When I fixed that, the ignition box/coil went out.
Old 06-16-2004, 08:27 AM
Moke81's Avatar
I have another test and that is to lift up the airflap but I still think it's the fuel pump past records shows it has never been changed.
Old 06-16-2004, 04:21 PM
Be warned Mr. Barclay,
When I removed my belly pan to change the fuel pump I found the tie rod boots were deteriorated. It turned into a complete front suspention replacement.
One old pump...
1979 911 SC Targa
Old 06-17-2004, 04:51 PM
