headlight problem
Hi:
we painted the car over the winter and replaced the front fenders...the painter put the headlights in and now i only have low beams..and the fog lights dont work). with the key on and the headlight switch pulled out, when i push the highbeam/flasher to highbeam the lights go out...when i pull the switch to the flash position the low beams stay on. when in the middle position the low beams are on. I looked at the wiring diagrams on this site and in the haynes numerous times Question 1: does the highbeam switch send power to energize the coil in the headlight relay when in the highbeam/flasher positions or in the middle position? Question 2: which fuses are highbeam? (i cant read the diagram). question 3: If i disconnect the 3 wires going to the highbeamflasher switch what continuity should i read when the switch is in the 3 positions? any help is appreciated. gary |
| All times are GMT -8. The time now is 12:38 PM. |
