surface rust question
I have replace my front pan, and am in the process of sealing it all in with POR-15 and 3M Rubber Undersealant. I have noticed that parts of the new pan and old metal, along the front have developed surface rust in the void between them. I can see this through the drilled-out spot weld holes. Will this become a rust problem from humidity in the air, assuming this will not be a natural wet spot? I would like to spay some rust deterring solution in all possible voids, but am not sure what is best for this purpose. POR-15 does not spray well, and I am thinking more of a zinc or oil (WD-40). What products / solutions are best for this issue?
TIA, Doug |
Zinc will eventually sacrifice itself, and oils in the joints will probably just make a mess. POR15 sprays great, I've used it many times. I thin it down quite a bit with lacquer thinner.
I was starting to think that I should try that. What I need is some type of "wand" that I can drag throught the gap as I spray.... hmmm ....
Who carries POR-15 locally? Ya, ya, ya. I got my first batch from PP, along with my new Bently!!! (pretty cool by the way), but I am ready to seal this f****ker up so I can drive it! |
Are you talking about the box that is created in the space between the tank support and lower pan? Yeah you can do that too. Get some more POR - just mail order it from www.por15.com, they ship super fast. Then check out Eastwood - - they have an undercoat gun in there that has wands and flexible tubing for snaking into box sections. It's designed for undercoat but works just fine with POR15.
| All times are GMT -8. The time now is 04:18 AM. |
