B D B D is offline
B D's Avatar
Gears and Clutch
When you shift in to reverse you should hold in the clutch for 5 seconds or so before shifting easily in to reverse. But what about 1st gear should you hold in the clutch for a few seconds before shifting in to 1st?
68 911L
Old 06-18-2004, 02:59 PM
B D B D is offline
B D's Avatar
bump
68 911L
Old 06-18-2004, 10:44 PM
canna change law physics
red-beard's Avatar
If the Synchro is good, no. It should be able to synch for you. If you have to hold for 5 seconds, then the synchro is done and it needs replacing.
If this is the case, until you rebuild, only shift to 1st at a dead stop and only after shifting into 2nd.
James
Red-beard for President, 2020
Old 06-19-2004, 12:30 AM
