-   -   Mikey's B-day/Dad's present to self....it's a V8!!!! (http://forums.pelicanparts.com/porsche-911-technical-forum/168193-mikeys-b-day-dads-present-self-its-v8.html)
911ctS 06-18-2004 06:56 AM
Happy B day Mike. I think a solution to the low fifth is to take a 2nd gear "set" swap them around and put them in place of 5th. Not positive on accuracy, but this should get you down in the low 2k range at 65mph.
GrindingGears 06-18-2004 07:05 AM
Re: Mikey's B-day/Dad's present to self....it's a V8!!!!
Originally posted by mikez
http://914club.com/downloads/Videos/MikeZ.MPG
Right click and save to play....big file, not for the dial ups....
Mike that chuckle and wave... I nearly blew my breakfast out my nose....http://www.pelicanparts.com/support/smileys/lol2.gif
Happy happy!
sammyg2 06-18-2004 07:05 AM
2nd gear is fixed on the input shaft of the 901. Unless you can find a very rare and expensive racing version of the input shaft you can't play with 2nd gear at all.
if I remember correctly either 3rd or 4th is used in the flipped position to make 5th gear higher.
And I never could figure out the logic of removing or locking out first gear. Why in the world do they do that? I know it is the weak link, the obvious solution is to just don't use it under full power.
1st gear is very useful to pull into the garage or to put the car on a trailer, it just takes a bit of self control not to use it to do burnouts.
Besides, on my V8 914 I prefered second gear for the burnouts because I could get more tire smoke ;)
GB83SC 06-18-2004 07:07 AM
Mike, Don't sweat 47 I am right there with you in November.
1957 Just a Baby!
Ray 911s 06-18-2004 07:25 AM
September 16, 1957 here.
Happy B'day and very cool car. Congrats.
Wrecked944 06-18-2004 07:56 AM
You can flip gears ??????
sammyg2 06-18-2004 08:25 AM
I have not personally done it, but but I was told by Scott Mann at Renegade that one of the gear sets (either 3rd or 4th) can be assembled in reversed order to obtain a higher ratio.
In other words, put the output gear on the input shaft and versa visa.
Obviously if a gear set has an established wear pattern installing it in a different orientation could cause unusual wear or noise.
If I were to do it i would prefer to use a new gear set unless i had a set that was in near new condition.
Joe Bob 06-18-2004 08:51 AM
I still think that a R&P swap on a known GOOD 901 trans would be the easier swap.....
Zeke 06-19-2004 08:54 PM
Originally posted by Early_S_Man
<b> Let's see how many Dodge-hating morons...........</b>
Are those terms mutually inclusive?
k9handler 06-19-2004 09:45 PM
well we need more pics of the monster!
