oil drain plug gasket
I recently purchased the pelican basic maintenance kit and am getting ready to do my first oil change. Well the kit came in and if the oil drain plug gaskets are here they are not marked. I think I figured out what they are, but can someone verify that the picture below is the gasket used on the oil drain plug? In a previous post someone mentioned that the gasket for the engine and tank plugs are different? I have 2 that both look like below. Will that work on engine and tank?
85' 911 Coupe
sw chip, ghl sport cat, M&K sport muffler, short shift, magnecor wires, heat sheets, cool collar, Momo anatomic leather shift knob...
Old 06-19-2004, 06:33 AM
They are the same size and are used interchangeably. Those are them. They are called crush washers.
Mike
1986 930
Old 06-19-2004, 06:43 AM
IROC's Avatar
My tank drain plug is a different size than the engine case plug. I've never known why...I used to think everyone's was that way.
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 06-19-2004, 06:50 AM
Thanks a lot Mike!
85' 911 Coupe
Old 06-19-2004, 06:52 AM
Send a message via AIM to Oldporsche
Cool
These can be bought at Pep Boys. They come in a number of different sizes. I have often wondered, given Porsche's penchent for exactness, that the factory ones didn't fit better.
David Duffield
Old 06-19-2004, 06:54 AM
Semper drive!
rcecale's Avatar
Here's a question for you...and I don't mean to hi-jack this thread, but...it seems as though the seal on my engine drain plug is leaking pretty good, so I'd like to replace it. Unfortunately, I only have 350 miles on the oil that's in there.
Aside from just trying to pull the plug really fast and plugging the hole with my thumb and swapping out the seal, does anyone have a better way of doing this?
Randy
84 944 - Alpine White
86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten )
One Marine's View
Igitur qui desiderat pacem, praeparet bellum
Old 06-19-2004, 07:03 AM
gerard vaglio's Avatar
Randy,
You could just drain the oil thats in the engine into a large receptical, change your crush washer and then use a funnel to pour the oil back into the tank.
If you have a helper to hold the funnel and you go slowely, it will keep you from spilling any oil on the engine.
Gerard
Old 06-19-2004, 07:15 AM
Semper drive!
rcecale's Avatar
Thanks, Gerard, that just may be the way I go. Appreciate the quick response.
Randy
<We now return you to the original thread, already in progress... >
One Marine's View
Old 06-19-2004, 07:37 AM
vash's Avatar
randy, i have a brandnew drain pan hermetically sealed in a trash bag just for that purpose. embarrasingly enough, i have used it three times. usually because i dumped the oil to fix something, only to find i need to fix something else that required more oil dumping. sooner or later, i will get it. i need a big bag of crush washers.
poof! gone
Old 06-19-2004, 10:44 PM
I use the same crush washer a few times because I haven't had a used one leak..
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 06-20-2004, 12:04 AM
Semper drive!
rcecale's Avatar
Hmmmm, a new funnel or a new drain pan..... Seems like the drain pan would make this a lot easier. Thanks Vash! Sounds like my new plan of attack.
Randy
One Marine's View
Old 06-20-2004, 06:26 AM
KTL KTL is offline
Schleprock
KTL's Avatar
The crush washers for all of my fluid drain or fill plugs (engine, oil tank and transmission) are the same size. 22x27 mm. For some reason the washer I get for the oil tank is copper. Aluminum, copper, plastic, what's the difference? As long as it seals the connection between the plug and the reservoir, it's good enough for me.
And like Ron said, you can usually reuse these guys a few times as long as you don't Hercules-tighten your plug each time!
Kevin L
'86 Carrera "Larry"
Old 06-20-2004, 07:49 AM
