So that is what a Barrel nut is!
OK so I have been goin crazy over this noise I hear under acceleration....
I got the drivers side exhaust valve cover off to take a peek, fearing broken studs.....i find a completed unscrewed nut on the outside of cylinder 1.
I hear you cant really retorque them correctly....but I guess all I can do is screw it back on and torque it down as best I can....
I think this is good news as I found a problem and it isnt a broken stud....
Has anyone else ever found the nuts to just come loose like this?
Old 02-22-2004, 05:24 PM
Re: So that is what a Barrel nut is!
I don't understand this - are you saying that you can't retorque your specific stud nut, or that "in general," you can't retorque?
You should be able to get a torque wrench in there and it should hold torque over time...it's common to check head stud nut torque at valve adjustments.
Old 02-22-2004, 06:11 PM
Pat S's Avatar
What engine do you have? If it's a 2.7 then you more than likely have a pulled headstud. They pull out just enought to loosed the nut to where it vibrates off.
I had no less than six of these. I didn't even attempt to retighten and just rebuilt. Do some searches on pulled head studs, time-certs or case savers to get lots and lots of info, but be-warned, it's scary (read as $$$$).
If you only have one, You can try retorquing it. If it is pulled it will come loose again someday.
You do risk damaging the cylinder to head seal areas if you can't maintain a good seal there.
Pat
Current: 07 S4 Avant, 06 Volvo S60R
Sold: '74 911, 01 986, 93 Volvo 240
Old 02-22-2004, 06:35 PM
19 years and 17k posts...
azasadny's Avatar
I just had yhe same thing happen to me (barrel nut on cyl #1 was completely off the head stud, but I was able to put in back on, torque it and it held. Am I buying any time here?
Art Zasadny
Learning the bass guitar
www.ford.com
Old 06-18-2004, 04:36 PM
Hilbilly Deluxe
emcon5's Avatar
I am guessing by his handle, "1980 911 sc" he may have a 1980 911sc.
I haven't had a problem getting a torque wrench in there. All you need is the correct size allen head socket.
Tom
82 911SC Coupe
GTI Cup #43
Old 06-18-2004, 04:41 PM
canna change law physics
red-beard's Avatar
Originally posted by Wayne at Pelican Parts
Having a loose nut in there is usually not a good sign...
-Wayne
There are lots of loose nuts in here!
James
Red-beard for President, 2020
Old 06-18-2004, 05:57 PM
Doug Steinel's Avatar
Wayne, that is the understatement of the year.
77 911, 3.0L
Old 06-18-2004, 07:59 PM
