Easiest Wiring Route through Firewall?
I have an 87 911 and want to run RCA cables from the stereo into the front trunk for a subwoofer installation. What is the easiest route through the firewall for these wires (with minimal taking apart the car)?
Thanks.
Old 06-18-2004, 03:18 PM
david914's Avatar
There should be a hole (~1 inch diameter) behind the radio that some of the factory wiring goes through. If you're careful, you can probably squeeze the RCA connectors through without too much difficulty.
David Dryden
'86 911 Coupe
'05 BMW X5 4.4i
Old 06-18-2004, 03:25 PM
