Location of 6 pin connector
Anybody know the location of the 6 terminal multi-connector (#85 on the schematic) on a 1973.5 911?
I sure don't see it in the engine compartment..... |
Extreme left rearmost corner of engine compartment ... extends [via 'other' side of panel-captive socket] out into the fender area to which harness from left tail-light assembly plugs into. Right side has the 'mirror' connector for right tail-light assembly and oil lever sender harness.
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Somehow I knew you would know this....
Followup: is this #85 the round connector that plugs into the area of the tail light? |
Randy,
Yes, the taped-up harness [if still intact] from the lamp assembly plugs into #85. Actually, after looking at the diagram again ... both sides are identified as #85, which I had forgotten that the factory identified in such a generic way.
Thx - I understand now.
