dino vs. synthetic running temps
I changed oil last week for the first time since a top-end rebuild on my 82SC. The car had Castrol Syntech since the rebuild, but I went with Castrol GTX 20w50. I don't drive it that hard and I perform frequent oil changes. However, after a ride, I noticed that the oil temp gauge was reading slightly higher than it was prior to the oil change. Is this normal? Does synthetic run somewhat cooler than dino?
Thanks,
'82 911 SC
Old 06-23-2004, 11:04 AM
PRO Motorsports
Tyson Schmidt's Avatar
Yes it does. The reason is that the more consistent viscosity of the Synthetic makes the oil coolers more effective at transferring heat.
The dino oil will tend to thicken up and slow down near the cooling surface of the cooler, where the dino oil will keep flowing, increasing the amount of oil that can be cooled by the outside air.
I've noticed a 10-15 degree difference between dino and synthetic.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 06-23-2004, 11:10 AM
KobaltBlau's Avatar
Tyson, what synthetic(s) are your experiences with?
A not-too-technical guy at the track claimed he got a 10 deg temp drop going from mobil 1 to redline (on a 930). Can anyone lend credence to this...?
Thanks in advance.
Andy
Old 06-23-2004, 01:51 PM
PRO Motorsports
I'm comparing dino oil to Mobil 1 synthetic. I have no experience with Redline other than in a transmission.
2004 GT3
Old 06-23-2004, 02:06 PM
vesnyder's Avatar
Send a message via AIM to vesnyder Send a message via Yahoo to vesnyder
My experience has been similar, but cannot quantify. The synthetic seemed to run considerably cooler?
Vance
'83 SC Cabriolet - The "Matrix"
'73 914 - "Spicy Mustard" - SOLD
Old 06-23-2004, 02:26 PM
KobaltBlau's Avatar
15W-50 mobil 1 (right?) and what Dino? Seems like weight grades could make a difference here on top of the synth/dino difference...
Thanks in advance...
Andy
Andy
Old 06-23-2004, 04:56 PM
PRO Motorsports
Yes, 15W50 Mobil 1 versus 20w 50 dino.
2004 GT3
Old 06-23-2004, 05:34 PM
