Send a message via Yahoo to TJ Hemrick
Big Brake upgrade
I got a great deal on a set of 928 GTS rotors and calipers and want to know what type of adapters I might need to fit them on my 86 Carrera. I checked the archives and found a little info but nothing really helpful. Any advice would be much appreciated.
TJ
Old 06-24-2004, 04:57 PM
MBruns for President
JeremyD's Avatar
all you need to know
Old 06-24-2004, 06:17 PM
Has anyone ever seen a performance comparison between "Big Reds" and stock Carrera brakes?
1987 535is, 1966 GTV, 2015 F-Type R, 2013 991 C2, 2011 E550c, 2007 997 C2S, 1987 911, 1958 356 1600s, 1956 356 1600s
Old 06-24-2004, 06:31 PM
JeremyD's Avatar
Look on Bill Verburg brake page he has comparisons of pad size/swept area, etc. From the ones in the know that I have talked to brake sizing can be somewhat of a black art that takes into account car weight, speed, temp, rotor size, pad material, cooling, fluid condition and type, and braking technique...
Old 06-24-2004, 06:45 PM
Bill Verburg's Avatar
I guess if Jeremy says that's all you need to know then I guess shouldn't mention the fact that 928 rotors can't be used on a 911 w/o machining the hubs.
The GTS front caliper is a Big Red painted black(usually) w/ the bleeds and feeds reversed. They can be used w/ an appropriate 322x32mm front rotor(VCI can supply that and the caliper adapter) if the bleeds and feeds are swapped.
The rear will be a problem, the rotor cannot be used and the caliper has inappropriate piston sizes. The 28/30 is way too small for use on a 911 w/ the Big Red front.
If the GTS front caliper is used, you will want either a modified 965(VCI does supply one version of a modified 965) rear on a 930 rotor
or a modified 993RS rear caliper on a modified 993RS rear rotor. IMHO you will want the latter setup.
Yes
Bill Verburg
Old 06-24-2004, 07:14 PM
JeremyD's Avatar
All you need to know and a link to the VCI webpage - They were very helpful, especially when it came to questions regarding what calipers and rotors will work with what...
Old 06-24-2004, 07:42 PM
