Another exciting throttle linkage thread! Yay!
Hi friends,
I've read about 2,000 throttle linkage threads, but unable to find one with the symptoms I'm seeing. I was wondering if anyone could help. Here's what is going on: Car: 1988 911 Carrera, 100k miles. Stock w/ Steve Wong chip.
Thanks for any ideas! |
Re: Another exciting throttle linkage thread! Yay!
Hi -
Check your micro idle switch for continuity/adjustment. It is the smaller switch located on the throttle body housing. Sorry, I don't have a picture handy. |
Hmmm, did a search for "idle switch" and found this thread: http://forums.pelicanparts.com/showthread.php?s=&threadid=112494&highlight=idle+s witch Which looks pretty similar to my problems! I'm going to check it out now. Thanks for the lead. |
Try for a vacuum leak at "operating temperatures".
This is where the efi guys need to chime in. david Duffield |
Okay, just got done with fiddling with this a little.
It looks like my idle switch sender(?) is bad. I tighted up the return spring on the throttle (shortened the spring). I also tested the idle switch by hooking up a meter and I could tell that something was happening when I pushed on the throttle - it showed some movement on the meter. I could also hear the switch "click" at just the right moment - every time I moved the throttle, the return spring would easily apply enough pressure for me to hear the "click". I took the car out and it felt a little better, but again after warming up, the idle would hang at 2k. I got out and pushed hard on the throttle from the engine compartment and the revs dropped to idle instantly. Tried it again, and same thing. It looks like when I push the throttle level in hard, the switch is engaged further and the car drops to idle. So even though the switch is 'clicking', it's not sending that signal to the DME until I -really- push it. I have a couple questions: 1) Even with the idle switch not fully pushed, the throttle is CLOSED. There's very very little movement to close that switch fully (about 1mm or less). Why would the car hang at 1500-2000 rpm with a closed throttle even if the "idle" switch wasn't closed. Doesn't that seem weird? 2) Is it common for these switches to fail? When I had the car off, I ran my finger over the top of that switch and things were pretty dirty. I can imagine that it's full of dirt and not making a complete contact. 3) This looks like a b*tch to replace! Time for the shop? Thanks everyone! |
Check your Lamda sensor.
Sometimes when the throttle linkage slack is taken up from between the linkage between the tranny pivot and throttle body, and too much slack is taken up, it will cause the throttle butterfly to close the microswitch intermittently, thereby causing the intermittent hanging idle. Make sure there is enough slack in the linkage here to allow the switch to close, and often throttle slack preventing wide open throttle switch engagement should be taken up on the linkage between the gas pedal and the tranny pivot. You an see the idle microswitch at the end of the pen tip. The little red button is the switch, and you can see the acutator arm that is supposed to activate it.
http://forums.pelicanparts.com/uploa...1088296822.jpg |
Thanks for the replies, guys.
Steve: the picture made things clearer, thank you. I double checked the clearance of the idle switch sensor and it seemed fine. I also double checked the length/play in the linkage between the pivot and the throttle body - there was some play in the linkage (didn't feel too taught to cause this). I had to take the car in for state inspection, so I'm going to let my shop take a peek and see what they say. I'll post results here so this can help someone in the future. |
| All times are GMT -8. The time now is 06:24 PM. |
