Question rear fiberglass bumper questions/advice needed
Hello,
I would like to install a rear fiberglass bumper on my SC. Any brands that I should stay away from?. Are used tough to come by? Do they bolt to the existing bumper shocks?? any advice is appreciated!
thanks, Matt
Old 07-18-2004, 11:08 PM
Matt,
You will want to remove the existing bumper shocks for the huge weight savings. I had a shop put a FG bumper on. I am sure it is not as easy as it looks. Some amount of fabricating has to be done like making brackets and cutting out for the exhaust pipe.
I was advised to choose a fiber glass bumper that had the series of vertical slots across the lower lip to provide better cooling for the exhaust system.
JoeF
Old 07-19-2004, 04:03 AM
Bill Verburg's Avatar
My B&W pretty much bolted on
Ditch the bumper shocks, bolt to the fenders
Bill Verburg
Old 07-19-2004, 04:11 AM
Thanks guys,
If I lose the bumper shocks, does the new bumper somehow attach to those two points. Seems like the center area of the bumper needs to be supported somewhere in addition to the fenders. Bill, those slots look great and they must be functional too! 5 years ago I removed the giant black bumper pads, but now I would like to go the next step!
thanks, Matt
Old 07-19-2004, 08:05 AM
we've made an additional center support between the tail lamps by using 1/8" aluminum sheet. It sticks out below the reflector like a someone sticking their tongue out. We bend a gentle S curve into it across the width of the reflector so the bumper to body seal is left intact and the fiberglass bumper slides over the top of the tongue. This way the resulting sandwich of alloy sheet, then bumper , gives it additional support and heat insulation. Remember to round the edges of the "tongue" so the corners don't bite into the bumper. Between the extension support tubes, the edges of the rear fenders, and this, you will have a very solid installation
1970 914-6 street"evil cockaroach"
1970 911 Targa "ST"
Jade Green IROC Tribute (ready to race)
Old 07-19-2004, 09:00 AM
Sounds like a great solution! Thanks again!
Matt
Old 07-19-2004, 10:13 AM
Hello again,
How did you attach the new aluminum sheet tongue to the existing body sheet metal? Drill holes and use small nuts/bolts? thanks again,
Matt
Old 07-27-2004, 09:34 PM
ipapilot's Avatar
One of our guys has a new BW ruf rear bumper for sale on the parts page for $400...
Brian Starr
Alabama Region PCA
1983 911SC/Rebodied as 993 w 3.6
1995 911 C2 (Sold)
Old 07-27-2004, 10:10 PM
Brian,
I just purchased one from Rennspeed. thanks though!
Matt
'77 911S w/3.2
Old 07-28-2004, 08:50 PM
