| Registered Join Date: Oct 2003 Location: Savannah, GA
				0.19 amps on #4 normal? - doors, hood closed
			Pelicans,  modded 930 (it's the modded part that's probably at the root of this evil...) With the hood and doors closed, the glovebox light turned off, no clock and the radio on a seperate circuit, I'm still drawing 0.19 Amps on the #4 fuse. Is this normal? I would have thought that this circuit would go to Zero in this state. What else could be connected to this line? Regards, Lomotpk P.S. The modded comment refers to alot of 'creative' electical work done by PO's | ||
|  06-26-2004, 05:29 AM |
| Registered Join Date: May 2001 Location: Peoples Republic of Long Beach, NY
				Re: 0.19 amps on #4 normal? - doors, hood closed
				__________________ Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 | ||
|  06-26-2004, 05:35 AM |
| Registered Join Date: Jun 2002 Location: Richmond, VA
			Shouldn't be anything if that's the fuse I think it is (Left side parking lights and engine compartment light). Does the car have an aftermarket alarm? Check for any non-factory wires attached to the fuse.
				__________________ David Dryden '86 911 Coupe '05 BMW X5 4.4i | ||
|  06-26-2004, 05:49 AM |
| Registered |
			What year chassis is it? Does it have the factory alarm option?
				__________________ Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' | ||
|  06-26-2004, 08:34 AM |
| Author of "101 Projects" |
			Doesn't quite seem right to me... -Wayne
				__________________ Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports | ||
|  06-26-2004, 09:45 AM |
			84 Chassis 930 No alarm from what I can tell. There is only one, small gauge black wire coming off the #4 fuse. On the card #4 is for "Interior lights, radio, clock"
				__________________ 930 no more. 997 GT3 no more. 912 targa more. 914 now! | ||
|  06-26-2004, 11:08 AM |
| Registered Join Date: Dec 1999 Location: Novato, CA
			Actually .045amps-.060amps is the same as 45-60mA and 0.19 amps is the same as 190mA. So 190mA is way over what you need to be seeing of 45-60mA. Joe Last edited by stlrj; 06-28-2004 at 12:04 PM.. | ||
|  06-28-2004, 09:56 AM |
| Registered Join Date: Aug 2002 Location: Galivants Ferry, SC
			Point of reference....stock 85 Carrera standby loss ( clock)...15-17 mA Later 964's go up to about 64 mA...most then require a chipped trickle charger to avoid a flat battery. Common convention is anything over 100mA is prolly too high... start checking. --Wil
				__________________ Wil Ferch 85 Carrera ( gone, but not forgotten ) Last edited by Wil Ferch; 06-29-2004 at 06:43 AM.. | ||
|  06-28-2004, 10:46 AM |
