External T stat replacement
I've got the 77' external cooler,that needs a T stat,..is there a direct replacment or a repair kit,...Thanks Frank
So are you saying that your car has a thermostat in it which isn't opening and needs to be repaired? If so, you can get a new thermostat cartridge which fits in to the existing t-stat body. Our host, of course, sells them.
Easy, if you can get the old one out. The old fittings can be pretty hard to get into. c |
Ok Thanks I'll ck that out....Frank
Thanks,...I was able to remove the T stat,..is it safe to run engine with it out until replacement arrives....Thanks Frank
huh, no.
unless you connect the two open ends with a loop. and that would be a pain in the arse. wait, you only removed the guts? or the entire TSTAT? |
Correct,..just the guts...?? should not hurt a thing right..Frank
nice job on getting the guts out. i understand the lack of space makes it a beotch. good job!
i dont know if you can drive it like that. you basically took out all the one way valves in the system. so the oil will not go in any specific direction, right? |
| All times are GMT -8. The time now is 01:20 AM. |
