Porsche Crest External T stat replacement
I've got the 77' external cooler,that needs a T stat,..is there a direct replacment or a repair kit,...Thanks Frank
Old 06-28-2004, 12:15 PM
echrisconnor's Avatar
So are you saying that your car has a thermostat in it which isn't opening and needs to be repaired? If so, you can get a new thermostat cartridge which fits in to the existing t-stat body. Our host, of course, sells them.
Easy, if you can get the old one out. The old fittings can be pretty hard to get into.
c
'76 911 Carrera 3.0
Old 06-28-2004, 12:40 PM
Ok Thanks I'll ck that out....Frank
Old 06-28-2004, 12:54 PM
Hald's Avatar
This is probably what you need. Available from our host here .
I've been able to grab the outer edge of the cap with a large channel-lock pliers & unscrew it.
Mark
'77 Carrera 3.0
http://members.rennlist.com/hald
Old 06-29-2004, 12:02 PM
Thanks,...I was able to remove the T stat,..is it safe to run engine with it out until replacement arrives....Thanks Frank
Old 06-29-2004, 12:43 PM
vash's Avatar
huh, no.
unless you connect the two open ends with a loop. and that would be a pain in the arse. wait, you only removed the guts? or the entire TSTAT?
poof! gone
Old 06-29-2004, 12:57 PM
Correct,..just the guts...?? should not hurt a thing right..Frank
Old 06-29-2004, 01:10 PM
vash's Avatar
nice job on getting the guts out. i understand the lack of space makes it a beotch. good job!
i dont know if you can drive it like that. you basically took out all the one way valves in the system. so the oil will not go in any specific direction, right?
poof! gone
Old 06-29-2004, 01:18 PM
