Its just some profile rubber, Pep Boys or for more of a selection Pegasus Racing products
To the race/lightweight guys... Thrownhammer, and Bob T. specifically...
Where did you get the hinges you're using on your decklids? I need a set of those for my RSR project...:D |
http://forums.pelicanparts.com/uploa...1088469774.jpg
This is the Toad Hall R that was at Rennsport. |
I agree the diamond mesh on my R clone is kinda Home Depot-ish
The powder coating helps but when I did that it was 6 years ago( just learning) ( more experience today) if I ever re do it Pegasus racing carries mesh thats does not have that "construction" material look to it, for my applicaton you need to use spacers to keep the mesh from having that wavy look to it |
http://forums.pelicanparts.com/uploa...1088470232.jpg http://forums.pelicanparts.com/uploa...1088470280.jpg
An ST, and the Targa Florio winning RSR. Interestingly all three are factory items, yet very different execution. |
Geof33- Re: deck lid hinges. Shawn had those made up out of titanium. He was working on a deal to have more made but it fell through. I'm sure he'll chime in here with the exact scoop.
Shawn, I like the clean look of the grill on the white 911R from Toad Hall. Nice clean straight edges. You might even save an oz. or 2 by trimming off the flanges used for fastening the old grill in place. I hope you have a safe color in mind for this thing! |
Here are wts. for the stock grill (lbs.):
Engine lid grill, 1975, plastic 2.4 Engine lid grill, 1973, metal 2.5 These are accurate wts. determined using a NBS traceable scale. |
Hey guys. Thanks for all the pics! So I gather that you just take a stock grille and remove the slats? Thats easy enough. Or I could get fancy and fab something up out of expanded aluminum....
As for the hinges. I made about 6 sets out of Titanium. They are welded grade 2. Weighing 2 ounces a set. I sold them to Pelican heads. I ended up keeping one set for myself. I am not sure where Mr. Tilton got his set. I do like the Toad Hall R grille. But if I cut the tabs off then I have to paint again.....I dont like painting. |
A friend of mine has used the home depot stuff on his Saab, it looks and holds up great.
Almost all it can be had thru McNichols catalogue including Mark Minkoff's fine mesh and at much less in price than Pegasus. |
I think I will use expanded aluminum mesh and use Titanium strips for support on the ends and in the center.....
those are some cool pics garfield.
i remember when my car was in the body shop a guy brought some screen in to install on his aftermarket f/g bumper. it was a very close match. i believe he picked it up from a "ricer" shop which means he probably paid good money for it...i don't know. i don't have R hinges for my decklid. had a set from gt racing and sold them. the ti hinges looked great. |
geof33 asked:
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/152062-911r-engine-lid-hinges.html Andy |
Milt's right on about McNichols. I have had good luck with them as a source for mesh/wirecloth products for my car projects. If there is a distribution center in your area (there is one here in ATL), you can see samples in their showroom. I believe they will also send samples by mail...
R-inspired grill with 3D mesh. 750 gram unit (Aluminium).
All hand made (except for laser cutting the base frame) the frame is bent in shape on an english wheel, bores are sunk, mesh is crafted into shape to fit the inserts, custom bushings hold the frame flush with lids edge https://up.picr.de/37870227mx.jpeg https://up.picr.de/37978247rl.jpeg |
| All times are GMT -8. The time now is 12:28 PM. |
