-   -   911 engine swap roll call (http://forums.pelicanparts.com/porsche-911-technical-forum/169890-911-engine-swap-roll-call.html)
SalazarS2K 07-10-2004 05:36 PM
Engine:
http://www.salazar-racing.com/images/ACF552B.jpg
Where it lives:
http://www.salazar-racing.com/images/IMG_0118.JPG
Engine
-2.8 twin plugged GT4 race motor
-Weber 40IDA Carbs
-Phase 9 header
-Phase 9 exhaust
-Fuel Safe 17gal. fuel cell
-B&B front mount oil cooler
Transmission
-915 7.31 R&P
-Quiafe Differential
-Shortened gear set
-Factory short shift kit
-Protechnik shift lockout
Suspension
-Koni shocks
-Upgraded torsion bars
-Adjustable sway bars
-Weltmeister adjustable rear spring plates
-Rear trailing arm monoballs
-Turbo tie rods
-Front strut bar
Brakes
-Stainless Steel brakelines
-Pagid racepads
-Brake ducts
-Slotted rotors
Safety
-Sparco 5 point harnesses
-Sparco seats
-Safety Devices Rollbar
-2.5lb Fire Extinguisher
petevb 07-10-2004 05:47 PM
Other pics? Sure. These are not totally current, but...
http://forums.pelicanparts.com/uploa...1089506723.jpg
http://forums.pelicanparts.com/uploa...1089506775.jpg
http://forums.pelicanparts.com/uploa...1089506825.jpg
dean 07-10-2004 06:45 PM
Ok not many turbos so far.
81SC with 75 930 motor. G50 conversion, 930 brakes and now EFI. I also installed a front cooler last fall. Here is an old pic before the cooler. Last summer dynoed at 328 RWHP and 318 ft lbs of torque with CIS. I haven't dynoed with EFI yet.http://forums.pelicanparts.com/uploa...1089510207.jpg http://forums.pelicanparts.com/uploa...1089510298.jpg
