2.7l Internals
Will all 2.7L 911S internals fit into a 2.2 or 2.4 aluminum case?
What will the compression be? anyone.... |
yes they will fit. the 2.2 and 2.4 have magnesium cases, not Al. Compression will be determined by the piston and heads you choose. the stroke on a 2.7 crank is the same (70.4mm) as the 2.4, no increase in CR. The stroke is longer than a 2.0 or 2.2 crank (66mm). You may noticed above a point increase in CR but have to machine pistons to make it work.
2.7 911S internals will be based on CIS pistions and cams, not a good choice for a high output engine. you could keep the crank and rods. |
| All times are GMT -8. The time now is 06:16 AM. |
