Air Medal or two
afterburn 549's Avatar
"R" tail lights..do you ??
How many have installed these light weight babies and which vendor did you use, and of course there are a couple of diff styles...so your input and a pic ??
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 09-01-2006, 03:18 PM
ZLP ZLP is offline
Low Speed, High Drag
ZLP's Avatar
I think you mean R instead of RSR. RSR's used regular lenses.
Old 09-01-2006, 03:30 PM
I got mine from MotoDelta (moto-delta.com) in Illinois. The fiberglass pieces were of high quality and light, but the reason I bought them was because the lights are LEDs, not just to save a few pounds (which they definitely do). $258 inlcuding shipping and an extra-cost mounting piece. You have to paint them, of course.
Stephan
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 09-01-2006, 03:40 PM
Air Medal or two
OK "R" lights, thanx
Old 09-01-2006, 03:54 PM
Send a message via AIM to John Z. Goriup
I think you'll have the best results by contacting Mike Bazaglou (hope I spelled that correctly) at TRE in North Hollywood for the "R" lights you seek. His company distributes front and rear R lights that are built by Mike Swanson and are without question the finest and most authentic reproductions out there with the best fit. Naturally, you can expect to pay slightly more than the price you mentioned but quality and cheap are simply not compatible,....ever. Your biggest challenge will come in successfully scoring the correct front and rear Hella lenses that are authentic, rather than the approximate reproductions for sale. This week however is German Auto Fest, and I'd get my ass to Ventura if Porsche figures into your daily life, for surely there you will find most of what you need.
Good Luck
John Z. Longhoods 4ever
Regardless of what Graucho said, proud to be an R Gruppe member
Old 09-05-2006, 06:57 AM
It's Dave Bouzaglou.
Stephan
Stephan Wilkinson
Old 09-05-2006, 07:44 AM
Air Medal or two
thanx..exact repro is not a criteria just need a light thats light and cool
Old 09-05-2006, 08:13 AM
Super Moderator
cstreit's Avatar
Originally posted by John Z. Goriup
/... finest and most authentic reproductions out there with the best fit. Naturally, you can expect to pay slightly more than the price you mentioned but quality and cheap are simply not compatible,....ever. John Z. Longhoods 4ever
John,
I'm sure you didn't mean it this way, but you're implying that the fiberglass lights I carry are not of the highest quality. I would challenge that strongly. The fiberglass panels are impeccable and there are plenty of people around here that have them to attest to that.... No one that has installed them has had to refinish or "massage" them for fit at all.
The LED lights are not only of very high quality, they are also the only LED lights out there that are DOT approved, so for all the guys with state inspections we can provide the DOT certifications to show the inspectors. No problem.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 11-16-2006, 07:20 AM
Air Medal or two
I will vouch for ya cstriet. The fit is purrrffect, no problem, as for the little f.g. do dad shim you were talking about..I have no idea what it would do or why it would be necessary, as the fit is right pronto. No problem. No massaging, no grinding and re do, drill the two holes,
( shown clearly on them ) adjust the metal backing plates on the car and screw them on. Ya might want to paint them.....i did
Old 11-16-2006, 07:29 AM
Me too. Mine are of the highest quality.
Stephan Wilkinson
Old 11-16-2006, 07:37 AM
thrown_hammer's Avatar
I bought mine from Ray who I believe now supplies Chris. They are very high quality. If you don't need a perfect restoration correct part and are just wanting the look. They are the way to go. And by the wayI invented R lights. (not the crappy ones Mark Wilson stole off a tractor either...)
Keeper of the Titanium Monkey
1975 911S (sold)
1973 911 w/3.2 (sold)
1983 911SC targa (sold)
Looking for a 987.2 or 981 Cayman
Old 11-16-2006, 09:49 AM
Montana 911
k9handler's Avatar
Send a message via Yahoo to k9handler
I am another guy who can tell you the moto-delta set are perfect.
H.D. Smith
2009 997.2 S 3.8 PDK
2019 Ford Ranger Lariat FX4 Baby Raptor
2019 Can Am Renegade 1000R XC
2020 Yamaha YFZ450R
Old 11-16-2006, 10:22 AM
Sultan of Sawzall
rouxroux's Avatar
The only reason I did not get mine from Chris is because I wanted a "combo" amber/clear so I could have turn & back-up in 1 unit instead of having to fab up something else for back-up. I wound up buying mine from Pelican. .
Gruppe B #319
'66 Monza coupe 110/PG(white)
'95 993 cabriolet (wife's)
Old 11-16-2006, 11:03 AM
Mine are from Mike Swanson (AR Concepts) and the fit is perfect.
87 Carrera Backdate
Old 11-16-2006, 11:41 AM
Ed,
That car is by far one of my favs!
1975 911S (sold)
Old 11-16-2006, 11:43 AM
Porsche virgin's Avatar
Are these units really that much lighter than the stock ones?
'08 RX350 (Hers)
'84 911 Carrera
'83 911SC Cabrio
'06 Miata
Old 11-16-2006, 12:39 PM
randywebb's Avatar
aka TRE Cup - his posting name
The stock units weigh 7.4 lbs ('73.5 911) for a pair. The R type ones save 5-6 lbs. at the extreme rear of the vehicle corners (where wt. savings has the max. effect on yaw; less so on roll or pitch since they are not that high off the ground). The savings is primarily due to the heavy cast metal housings P AG used on their lights -- LEDs will save little wt. over the bulbs and thin metal bulb sockets.
If you have not added a light wt. deck lid then the benefit is mainly cosmetic. If you have done that it is worthwhile - esp. if you have subbed ext. hinges, rubber tie downs for the latch mech., light mesh grill as on R types, and so on.
I don't like the gap they leave in the body colored areas (hard to see on dark cars) so am holding out for ones that take the stock lenses.
You need to retain backup lights - do a search.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 11-16-2006, 12:43 PM
Yeah Randy, Dude would have to be crazy to go that far...
1975 911S (sold)
Old 11-16-2006, 01:01 PM
drag racing the short bus
dd74's Avatar
The stock units weigh 7.4 lbs ('73.5 911). The R type ones save 5-6 lbs.
Is that weight you quote for each tail light unit, or for the pair?
The Terror of Tiny Town
Old 11-16-2006, 02:10 PM
randywebb's Avatar
pair - will edit above
nice street car, Shawn...
I hope you ditched the rear glass for a plexi backlight...
Old 11-16-2006, 02:49 PM
