pookie's Avatar
carpet install question
I am putting a perlon felt carpet in my car and was wondering what everyone else used for adhesive? I have some 3M spray adhesive but I was unsure if this would work or not.
Thanks in advance
Ryan
1976 911 S Targa 3.2
Old 07-01-2004, 04:39 PM
Zeke's Avatar
You'll probably need more than one can. I just put a kit in and I bought the other brand on the shelf which was Permatex "Body Shop Headliner and Carpet Adhesive." I liked it better. It tacked up sooner and repositioned fairly easy if I pulled it back right away and just touched up with some fresh spray. Believe me, that feature is handy.
Old 07-01-2004, 04:46 PM
CHILI's Avatar
I used brush on glue from 3M. I can't imagine spraying that stuff in a car with a dash, panels, a headliner and windows. The mist goes everywhere. When I use spray adhesive, I can feel it on my arms! And that's outside.
Milt, was your car complete when you did it?
"I understand that you want to drive fast, it's just that I want to go faster!" Move ova please
Chad aka "Chili"
1974 Base coupe in Carrera outfit.
No A/C, no Sun Roof, no power windows. Fast and light, just the way I like it. (Sad to say, it's sold. But at least it remains with us on this board.)
My car http://www.pelicanparts.com/gallery/CHILI
1969 RSR Project. Heavy on the word PROJECT! No pictures yet. Keeps breaking lenses of cameras.
Old 07-01-2004, 04:50 PM
motion's Avatar
I'm tackling my black carpet install in the 993 this weekend.. planning on using the 3M brush on glue. Are you guys just gluing the carpet down to the pan or are you installing a thin pad first?
'95 993 C4 Cabriolet
Bunch of motorcycles
Old 07-01-2004, 05:35 PM
pookie's Avatar
Where did you guys get the 3M bush glue? My question is that the carpet is thinner than what I took out I don't want the glue to go through and leave a mess after it dries.
Motion--I am just planning on gluing my carpet to the pan, but my car is pretty sparse. Anything has to be an improvement over the tri-color faded mess that I pulled out the other day.
I think the spray may be better for my application. I will let you all know what works out.
Old 07-01-2004, 05:42 PM
Motion - I just glued mine to the pan. I've read about some people using sound deadening material or paint. Not sure what the factory did in the 993.
Pookie - You may want to contact Bob at appbiz to find out what he recommends for Perlon carpet kit installs.
Old 07-01-2004, 06:02 PM
CHILI's Avatar
I got it at Home Dump! You apply it to the pan (I scrubbed mine with a firm brissle brush to remove all of the old glue. It was like sand once it was broken loose from the pan. I then vacuumed it up and sprayed the pan black so when you lift up the "floor matt" portion of the carpet, it wasn't yellow! Hehehhe). Then I brushed the glue on to the pan and let it dry a while as suggested. So, by the time you put the carpet on, it won't soak through. If it does, you've either used too much, or not waited long enough. I used the Appbiz kit and noticed it's not two pieces on the tunnel, like the stock kit was. So, in an effort to make it easier to do tunnel work, I velcrode the tunnel piece down with the high strength velcro. I can pull it up at any time and have a bare tunnel, but you can't tell by looking at it.
Chad aka "Chili"
Old 07-01-2004, 07:28 PM
D idn't E arn I t
RANDY P's Avatar
I've never been able to get 3M spray to work as advertised. I'd try the other stuff listed next time. It's messy. Use good ventilation too.
AOC/Hogg 2028
Old 07-01-2004, 07:39 PM
slater's Avatar
I had the 3m stuff work perfectly (spray). With whatever glue you use, make sure you find out what the max temp it is rated for. It gets pretty hot inside of a car in the summer, and some glues can become loose in the heat. The local upholtery shop told me that, and I called 3m to make sure. They told me not to use the glue i had and to use another glue they made. (I think it was super 77 I was using and I switched to super 78) Anyway, worked well. Easy install. Spray on both surfaces, let dry, and stick.
1977 MGB (bright yellow)
1985 Honda Spree Moped (great for towing rollerbladers)
A flute without holes, is not a flute. A donut without a hole, is a Danish.
Old 07-01-2004, 10:43 PM
efhughes3's Avatar
What Chili said. While the spray works also, who wants that kind of mist floating around your car?
I believe if you search, Bob at Appbiz recommends the brush on stuff.
I used the "gel" version of the 3M brush on in a 1 gal can.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 07-02-2004, 05:33 AM
84toy's Avatar
Use Headliner and carper adhesive spray made by Permatex. The nozzle is adjustable and comes out in a flat spray that is stringy and there is no mist to float anywhere. You can control the spray very easily. The trick when spraying the inside of the car is start the spray in the middle and move to the edges where more control is critical, this way you know exactly how the spray is coming out. I hope that makes sense. I recarpeted my entire car and there is not one bit of overspray and you won't run the risk of oversaturating the carpet with glue.
Before
After
Paul S
"Those who say it cannot be done should not interrupt the people doing it"
Old 07-02-2004, 07:52 AM
Nice Job Paul! What brand kit did you use?
87 Carerra Coupe
04 GMC Yukon
07 Mazda 3
00 GMC Sierra
Old 07-04-2004, 06:23 PM
Trust Me's Avatar
Just pulled my carpet. What's the easiest way to get all the left over glue and insulation out?
Troy
72' 911 T
97' Boxster
81' SC coupe / sold
76' slant nose
81' SC Targa / sold
77' s / sold
67' 912 / sold
89' 944 / sold
74' 914 / sold
71' 914 / sold
Old 07-04-2004, 07:08 PM
84toy's Avatar
Toolman, my kit came from World Upholstery and is Sliverknit, made in Germany
I removed my old carpet with a very sharp chisel and a sidewinder with a very stiff wire wheel.
Whole thing takes a weekend if you work at an easy pace
Paul S
Old 07-04-2004, 09:23 PM
Zeke's Avatar
Bob @ appbiz has a guy nearby that installs carpet. He uses bulk adhesive in a pressure pot spray gun. I sprayed alot of the carepet in the car using newspaper as a backup so my overspray didn't hit other interior. And the Permatex was a good find.
As mentioned, adhesive won't soak thru until you push it down and then you pushed it down too soon.
Old 07-04-2004, 09:56 PM
