Easy hood alignment
So I'm thumbing thru the Bentley book last night and stumble upon the front hood adjustment page (550-2). The front left of my hood had been slightly higher then the left. About 2 minutes after reading that page, the hood was nicely aligned. Just a couple twists of the rubber stops (duh)...no tools...all done.
Sometimes life is so busy that I miss the easy details like this one.
-Steve
'87 Carrera Targa
Old 07-03-2004, 03:14 PM
Gon fix it with me hammer
svandamme's Avatar
i got a different issue with mine
the allignement is correct, but the new rubber seal seams to be to thick
so it pushes the hood upwards
is that normal ? should i cut up the rubber ?
it is nicely settled in the chassis, can't push it any deeper
the lower side fits perfect, it's just the upper side of the fold that seems to rigid
Stijn Vandamme
BIMDIESELBMW116D2019
Old 07-03-2004, 03:35 PM
Designer King
Paulporsche's Avatar
I don't see how cutting the rubber could hurt.
Paul
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 07-03-2004, 04:35 PM
