Slumlord
Porsche_monkey's Avatar
Unhappy 915 Fill Procedure
Dopey questions:
I assume I should just pull the side plug and top up until it overflows out the side?
How do most of you get the oil in the top? Pump it?
Old 07-06-2004, 01:35 PM
I did mine at a local tech inspection. The shop provided a pump that looked kind of like the tube of a grease gun with a hose sticking out of the top. He stuck the tube in the oil container and pulled the handle sucking some up then stuck the tube in the top/side hole of the tranny.
Pushed it in.
I have an oil pump I use for the outdrive on my boat. This works like a bigger version of the pump on a windex bottle. These pumps screw into the top of the plastic quart oil container. It's cheap like $10 at the discount marine store and I think easier to control.
I was lucky I didn't need the big allen wrench for the plug.
I'd check yours before buying one.
Good luck!
Bill Miller
81 Targa Guards Red
3.6, M&K 1 out, S4 brakes
83 ROW CAB Rubinrot Metallic (RIP)
Old 07-06-2004, 02:17 PM
Gon fix it with me hammer
svandamme's Avatar
while in the car, you could pump it in using a plastic bottle
some do it by setting the oil canister on a ladder, and use a hose to the filler , then suck and gravity does the rest
there's some pics on a thread from couple of months ago
Swepco 201 Infusion, gravity and tight nuts
Stijn Vandamme
BIMDIESELBMW116D2019
Old 07-06-2004, 02:23 PM
Randy Webb's Avatar
Be sure to undo the fill plug before taking out the drain plug! Some have found they could not unscrew the fill and sat around for weeks with a dry trans while they beat at the plug with various weapons....
Old 07-06-2004, 03:11 PM
84toy's Avatar
I have a plastic hand pump that screws in the top of a one gallon jug and has a hose attached, you can buy them at Wally-Mart. I pour in the proper amount of fluid and with the car on jack stands, I pump until the jug is empty. I just changed my tranny fluid and it took about 15 minutes total.
Paul S
"Those who say it cannot be done should not interrupt the people doing it"
Old 07-06-2004, 06:28 PM
I use the gravity method, but rather than re-write several paragraphs, try the search button. There have been several threads on this and some good info in most of them.
Jerry M
'78 SC
Old 07-06-2004, 08:07 PM
You do not have permissi
john70t's Avatar
If the proper fill-plug tool isn't immediately available, you can get away by grinding the hex-head of a bolt to fit, and good vise grips close to it to turn.
Old 07-06-2004, 11:21 PM
Now in 993 land ...
aigel's Avatar
I have a fluid dispenser for these things that looks like an oversized syringe. About $20 at your favorite tool place. I like thetoolwarehouse.net, it has better quality than harbor freight.
HTH, George
81 SC (sold)
Old 07-07-2004, 01:12 AM
