B D B D is offline
B D's Avatar
Accelerator Pump rubber diaphragms
Can the two rubber diaphragms in the accelerator pump be reused? I broke a stud while tightening down and will need to remove the assembly, install the stud, and reassemble. Also should I use red or blue Loctite on the stud.
68 911L
Old 07-26-2004, 02:12 PM
Navin Johnson
TimT's Avatar
They can be reused, but how old are these diaphragms?
if they are old they can dry out , become brittle and tear, Since you are going to have to take the accel pumps apart, why not just replace them with new diaphragms?
'69 911 GT-5
'75 914 GT-3
and others
Old 07-26-2004, 03:01 PM
ditto
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 07-26-2004, 03:03 PM
B D B D is offline
B D's Avatar
I just rebuilt the carbs they are a few weeks old. I was just curoious, I'll stick with them.
What about Loctite blue or red?
68 911L
Old 07-26-2004, 03:32 PM
I think PMO suggests red.. even thou I delibartly used blue.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 07-26-2004, 08:57 PM
