How do you remove old weight adhesive from back of fuchs?
My fuchs have cleaned up pretty well, but the adhesive left from the weights doesn't seem to want to come off the back of the wheel. I guess the adhesive has never been removed because there are quite a few spots. Any trick to cleaning this off?
85' 911 Coupe sw chip, ghl sport cat, M&K sport muffler, short shift, magnecor wires, heat sheets, cool collar, Momo anatomic leather shift knob... |
3-M makes an adhesive remover. Any parts store.
Rick " too many people spend money they haven't earned to buy things they don't want to impress people they don't like" Will Smith |
wire wheel and a drill
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
M.E.K. Methyl Ethyl Ketone is the best but be careful not
to inhale and use rubber gloves. Next will be Naphtha. |
3.4 Bigger is better
I have been cleaning up a set of Fuchs and used toluol (toluene) to clean the inside if the wheels. Takes off all the adhesive, cosmoline and brake dust without harming the paint on the inside of the wheels. If the tires are off the rims this will also clean the black rubber marks on the inside rim of the wheel. Always use gloves and a very well ventilated area.
Michael 88 911 Diamond Blue CE Carrera 3.4 HC3.4 member 2020 Honda Passport |
GOO GONE or DE SOLV IT
works better than 3m adhesive remover it works |
