smestas's Avatar
Send a message via AIM to smestas Send a message via Yahoo to smestas
Cutting pre 74 headers
I recently purchased a cheap pair of headers off of ebay hoping to use them to backdate my exhaust. Since I’m not running any heat or A/C I cut all the tin of off them and the internal pipes were in great shape. Unfortunately the outer exposed pipes from the collector to the muffler flange are in bad shape. I was wondering if anyone here has ever cut this section off and moved the flange back closer to the merge collector and then used the common extensions to connect to the muffler. The extensions are the type that racers use to swap out from mufflers to use megaphones.
Simon Mestas
'78SC Coupe
My Pelican Page | AlfaBB - Alfa Romeo Forum
Old 07-12-2004, 03:44 PM
smestas's Avatar
This image might help to explain what Im thinking of. Does anyone know the part # or have measurements of the header extensions that go between the headers and muffler?
Simon Mestas
'78SC Coupe
Old 07-12-2004, 03:53 PM
smestas's Avatar
Hopefully I'd be able to modify my headers to use this type of extension.
Has anyone else ever done this before?
Simon Mestas
'78SC Coupe
Old 07-12-2004, 03:59 PM
Formerly bb80sc
Vipergrün's Avatar
I believe Pelican sells a replacement section, which is used on the pre-74 HE's...IIRC, only one end has a flange..
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 07-12-2004, 04:02 PM
If megaphones are used, seems like you have more leeway with the eventual end point. In this case, a muffler shop should be able to weld a flange onto the header collector, then fabricate an extension piece for each megaphone.
Sherwood
Old 07-12-2004, 04:20 PM
smestas's Avatar
I was thinking of cutting them and modifying them to mate up to a dual in dual out flowmaster.
Simon Mestas
'78SC Coupe
Old 07-12-2004, 05:31 PM
I was thinking of cutting them and modifying them to mate up to a dual in dual out flowmaster."
Same scenario. A muffler shop will have to fabricate pipes to the FlowMaster muffler anyway, so they should be flexible in configuring the routing.
Sherwood
Old 07-12-2004, 07:42 PM
