How do you remove the ventilation control panel?
You know, the panel with the 3 levers in an SC dash. I want to remove it so that I can fabricate some sort of housing to hold my data logger. How does this thing come out?
1983 911 3.6L - NASA GTS-3 class 1998 Boxster - PCA SpecBoxster, NASA GTS-2 2003 996X51 - NASA GTS-4, PCA GTB 2003 996 Carrera 2 Coupe 2003 Ferrari 575M |
Lie on your back in the footwell with your head resting on the tunnel in front of the shifter. You'll be looking right at the screw that holds it into a bracket behind the dash.
Very carefully
Mike 83 SC |
This might help:
Light Bulbs Behind Defroster Control Panel Question?
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
Thanks, looks easy enough, though I better start a pre-stretching routine based upon that linked thread.
