I'm not here.
K. Roman's Avatar
Fuel Pump stays on (buzzz)
My fuel pump stays on, never shuts off until the motor is shut off.
Anyone know how to get the pump to shut off?
"When do we say we can stop the Whole-Sale State-backed discrimination against straight white males? - island911 (This guy is insane, no?)
Old 07-11-2004, 08:35 PM
Send a message via AIM to fintstone
Maybe I misunderstand your question...but it is normal for your fuel pump to be on when your engine is running. Your engine would die soon after it shut off.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 07-11-2004, 08:41 PM
Administrator
Jack Olsen's Avatar
Huh? Do you mean it stays on after the motor is shut off?
Old 07-11-2004, 08:43 PM
I'm not here.
K. Roman's Avatar
Cutoff switch is disconnected. How do I reconnect?
Old 07-11-2004, 08:46 PM
Randy Webb's Avatar
Maybe it has gotten noisier and you didn't notice it before?
It runs as long as the ignition is on, even if the motor is not running -- say, before you start the starter.
Old 07-11-2004, 09:59 PM
Air flow switch is disconnected or bad. Look (feel?) for the connector on the forward side of the air box and rconnect if loose.
Old 07-11-2004, 10:40 PM
never ending projects
niner11's Avatar
I guess that you mean that the fuel pump runs when the key is in the on position and the car is not running. The easiest thing might be to try a different fuel pump relay. The contacts on yours may be permanently closed. Good luck
Old 07-11-2004, 11:42 PM
I'm not here.
K. Roman's Avatar
Yeah, that's what is going on. It makes a buzzing noise, and is really loud... always.
Old 07-12-2004, 12:03 AM
niner11's Avatar
The Bentley manual shows what conditions need to be met inorder for the fuel pump to run. With a voltmeter or test light I'd imagine that you could check for voltage at various pins where the fuel pump relay plugs in.
I'm on the road right now and don't have a manual with me or I'd list them for you.
Old 07-12-2004, 12:17 AM
Not Quite Banned
Thomas Owen's Avatar
As Jim mentioned above, the air flow switch usually gets disconnected to help with cold start issues. The fuel pump then runs as soon as you turn the switch 'on'. Did this just 'happen', or has it been going on for some time?
Good luck,
Thomas Owen
1972 911T
1972 911S
Old 07-12-2004, 03:47 AM
I'm not here.
K. Roman's Avatar
It's been happening ever since the purchase.
It was even in the PPI.
Old 07-12-2004, 07:26 AM
There is also a wire that could be disconnected by the 14-pin connector (it goes to the air-flow sensor plate switch).
Old 07-12-2004, 10:01 AM
