Crane Breakerless Conversion Install, need help
I just installed my Crane breakerless conversion in the distributor for my '72. I'm keeping the Bosch CD box for now. After reading the instructions for the 3rd time Im still not sure what the red and white wires get hooked up to:
The black wire goes to ground, correct? What about the white wire? Does this connect to the wire that was connected to the points? Red wire? Does this go with the blue/yellow wire from the Bosch CD on the coil (+). TIA |
ok, I got it.
Black -> ground White -> black/purple wire that used to connect to the points Red -> switched 12V from the bottom fuse on the fuse panel Timing is set. No more bouncing tach for me. |
| All times are GMT -8. The time now is 02:46 AM. |
