Licensed User
Shuie's Avatar
Crane Breakerless Conversion Install, need help
I just installed my Crane breakerless conversion in the distributor for my '72. I'm keeping the Bosch CD box for now. After reading the instructions for the 3rd time Im still not sure what the red and white wires get hooked up to:
The black wire goes to ground, correct?
What about the white wire? Does this connect to the wire that was connected to the points?
Red wire? Does this go with the blue/yellow wire from the Bosch CD on the coil (+).
TIA
Old 07-10-2004, 02:20 PM
Licensed User
Shuie's Avatar
ok, I got it.
Black -> ground
White -> black/purple wire that used to connect to the points
Red -> switched 12V from the bottom fuse on the fuse panel
Timing is set. No more bouncing tach for me.
Old 07-11-2004, 05:22 PM
