Decolliber's Avatar
A/C evaporator wiring harness question
In the smuggler's box there is an a/c evaporator relay (91161510301). Into that relay is plugged a wiring harness, the end plug of which is partially melted, so I want to replace it. I have found two numbers for this harness, but do not know which is the right one:
91161298400 ($16.41 at Pelican)
90161208400 ($13 at Pelican)
Porsche parts lists show the remarks "/LL" after the first one and "/RL" after the second, but since I do not know what that means it does not help.
Can someone tell me the difference between the two and which one is right for an 88 Carrera?
And yes, I have replaced the relay with the later one that has the fuse on it.
John C
1988 911 Carrera coupe
2002 BMW 530
Old 07-11-2004, 09:49 AM
Send a message via AIM to fintstone
I don't know if this will help, but the PET lists the 90161208400 number as the evaporator harness for an '88. Maybe you should call PP and ask.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 07-11-2004, 11:13 AM
