Any chance anyone can help my sc gearbox is starting to judder at shifter when letting clutch out in 1st when setting off and worse in reverse. the gears dont seem to drag nor is power down. once car warmer better and rest of changes as good as you get with these motors...... please any assistance is great thanks again Si
Sounds like a clutch problem not a gear box problem. Could be clutch is out of adjustment or worn out. Is the clutch slipping (car takes a while to catch up to engine speed) in the higher gears? Check the clutch adjustment.
You could still have an old rubber centred clutch on your car too. That shoudl have exploded like ten years ago but if your car is low mileage and not abused then it could conceivably have lasted this long.
jasper 2002 996 - arctic silver - PSS9, H&R sways,X51 oil pan, console delete, AASCO liteweight flywheel, gbox detent, RS motor mounts, 997 shifter. Great car. past: another 2002 996 and a 1978 SC with-webers-cams-etc. |
Irrationally exuberant
Yeah, what they said. It's 915 not g15. The "G" in G50 is for Getrag I think.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
It could also be bad engine or tranny mounts
Dean 911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno, |
Some history about car its a mint 83 sc coupe which has more history than England Its had everything done over last 15 years or so so hopefully just adgustment req, I originally owned car 2 years ago and it was fine a bit tight to select first when rolling forward but ok.,
Now i have just bought it back its been used as an every day car in traffic etc.... so a lot of start stop 1st gear in our fantastic traffic system, so how knows All i can tell is power is great no real dragginess to power revs on engine sound right per power delivery its just realy 1st gear where the car judders when moving off (while letting clutch out ) and in reverse the same but it not all the time sometimes its ok. i took her out for a paisting last night on country roads and it was mint not rocket power but shes older than most of the boy racers which seem to stick to my arse when driving.... hopefully this is more helpfull as wondering wether its a diy job or trip to specialist much apprieciated si ps excuse any spelling errors just got up ... |
My mistake its a 915 box im such a dummy dooaaahhhh.
I suggest getting Wayne's 101 Project book. It gives a detailed explanation as to adjusting the clutch.
Good luck, David
99 996 C4 11 Panamera 4S 83 SC Targa converted to a 964 cab (sold) 67 912 (sold) 58 Karmann Ghia choptop (traded for the 912) |
Were can i get this Project book, I have just been out again for an hour and car seems a bit better it didnt do it at all when cold this time and change was ok but it needs attn I am glad for the torque in 2nd and 3rd just drive all day round the tight and twistys. but You lads in the States dont have them do you your house drive way is probally wider than our country roads.......
Iam realy jelous though if i could be there i would move tommorrow (cheaper fuel and better coffee..) thanxs for help Si |
